Path to create the registry entries for load a .dll (vb.net file)
Hi:
I want to create a .reg file to load automatically a dll.
I would like to generate this file from Autocad (using a subroutine).
The entries are:
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.1\ACAD-9002:40A\Applications\SIMNET]
"DESCRIPTION"="Carga el archivo SIM.DLL"
"LOADCTRLS"=dword:00000002
"LOADER"="E:\\acaddlls\\SIM.dll"
"MANAGED"=dword:00000001
And I need to obtain from autocad next path " \Autodesk\AutoCAD\R18.1\ACAD-9002:40A" (is different for any versión of autocad).
How can I obtain it?
thanks
karea
StephenPreston
If you really want your .NET DLL to self register, you can use the technique described here - http://through-the-interface.typepad.com/through_the_interface/2009/05/creating-demand-loading-entri.... However,its better to let your installer add the appropriate entries so your user doesn't have to manually NETLOAD your DLL the first time.
And if you're using AutoCAD 2012, the new autoloader format removes the need for you to add your own demandload settings - http://through-the-interface.typepad.com/through_the_interface/2011/05/adn-devcast-episode-6-autoloa....
Cheers,
Stephen Preston
Autodesk Developer Network
Cheers,
Stephen Preston
I would like to create a .reg file and when the client execute it,  the registry is modified and when Autocad  runs, the application .dll is autoloaded. But I don´t know the version of Autocad in which it will be executed and therefore not the path that will be to introduce in the field [HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.1\ACAD-9002:40A\Applications\SIMNET].
The example corresponds with autocad 2011 but how it was for autocad 2009? and how it will be for autocad 2013?
It is possible to know it through some variable the application of Autocad?
thanks,
StephenPreston
Doing that in an installer is hard work - you need a custom action. And remember its not just AutoCAD versions, its also languages and verticals that have different registry keys. See the webcast recording "AutoCAD: Creating an Installer" posted to http://www.adskconsulting.com/adn/cs/api_course_webcast_archive.php for a review of this.
As for AutoCAD 2012 obwards - you won't need to do that any more because of the autolader feature I mentioned in my previous reply.
Cheers,
Stephen Preston
Cheers,
Stephen Preston
