Coming from VBA and new to VB.NET - Connect to Excel
joaosantos
joaosantos
Hi
I searched this group but didn't find the answer for this problem.
I want to export the layers names to Excel, as I used in VBA. I'm using AutoCAD 2011 (64b), VB Express 2010, Office 2003 (32b). I ran this routine in XP 64b and W7 64 with the same problem.
No problem in building the DLL, or loading it to AutoCAD. When running the command, Excel opens, but no workbook is created and I get this Unhandled exception error:
System.Runtime.InteropServices.COMException (0x80028018): Old format or invalid type library. (Exception from HRESULT: 0x80028018 (TYPE_E_INVDATAREAD))
   at Microsoft.Office.Interop.Excel.Workbooks.Add(Object Template)
   at Ligacao_Excel.Class1.Proj1() in d:\documents and settings\joão santos\visual studio 2010\Projects\Ligacao-Excel\Ligacao-Excel\Class1.vb:line 22
Line 22 is : folhaExcel = objExcel.ActiveSheet
Any help will be mostly appreciated. To program in VBA was much easier, but I recognize the .NET power, as soon as this can be dominated 🙂
João Santos
Portugal
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.Runtime
Public Class Class1
    <CommandMethod("LAY2XLS")> _
    Public Sub Proj1()
        Dim db As Database
        Dim bt As BlockTable
        Dim ms As BlockTableRecord
        Dim myDWG As Document
        myDWG = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = myDWG.Editor
        Dim objExcel As Microsoft.Office.Interop.Excel.Application
        Dim folhaExcel As Microsoft.Office.Interop.Excel.Worksheet
        objExcel = CreateObject("Excel.Application")
        objExcel.Visible = True
        objExcel.Workbooks.Add()
        Using trans As Transaction = myDWG.TransactionManager.StartTransaction()
            db = Application.DocumentManager.MdiActiveDocument.Database
            bt = trans.GetObject(db.BlockTableId, OpenMode.ForRead)
            ms = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
            Dim layerTB As LayerTable
            layerTB = trans.GetObject(db.LayerTableId, OpenMode.ForRead)
            Dim contador As Integer = 1
            For Each objecto As ObjectId In layerTB
                Dim MyLayer As LayerTableRecord
                MyLayer = trans.GetObject(objecto, OpenMode.ForRead)
                folhaExcel.Cells(contador, 1).value = MyLayer.Name
                contador = contador + 1
            Next
        End Using
    End Sub
End Class
michael_robertson
The 32bit Office & 64bit AutoCAD combination can cause problems with COM.
If your Excel files are in xlxs format you can totally skip using COM and requiring Excel to be installed on the machine by using the OpenXML.SDK from Microsoft. It allows you to read/write Excel and Word files independent on if the app is on the machine.
Here's the link to the Microsoft info: http://msdn.microsoft.com/en-us/library/bb448854.aspx
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Hallex
    Public Sub Proj1()
        Dim db As Database
        Dim layersList As List(Of String)
        layersList = New List(Of String)(New String() {})
        Dim oldCult = CultureInfo.CurrentCulture()
        '' This line is very important!
        Thread.CurrentThread.CurrentCulture = CultureInfo.CreateSpecificCulture("en-US") '<-- change culture on whatever you need
        Try
                ms = trans.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForRead)
                    MyLayer = DirectCast(trans.GetObject(objecto, OpenMode.ForRead), LayerTableRecord)
                    layersList.Add(MyLayer.Name)
                Next
            End Using
            folhaExcel.Name = "Layers"
            For Each layrName As String In layersList
                folhaExcel.Cells(contador, 1).value = layrName
            Next
        Catch ex As System.Exception
            MsgBox(ex.Message & ex.StackTrace)
            If ex.InnerException IsNot Nothing Then
                MsgBox("Inner excepyion: " & vbLf & ex.InnerException.Message)
        Finally
            Thread.CurrentThread.CurrentCulture = oldCult
        End Try
    End Sub
Try again
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
joaosantos
Thanks a lot Hallex. It worked perfectly. Now I will dig to understand this solution, never saw some of these instructions. Anyway I'm quite new to VB.
Also thanks to Michael for previous post. I went to the site but didn't had the time to search. But I will also study this clue.
Cheers
João Santos
