Passing textbox value to lisp function
bahman.jf.68
bahman.jf.68
Hi all,
I have designed windows form via C# for a lisp program. I need to pass some text boxes value on windows form to Lisp function then running the function.
Is it possible ?
_gile
You should provide more details. How do call the C# from LISP? If you use C# LispFunction method, this method can simple return a TextBox contents as a ResultBuffer which will be seen as a LISP list on the LISP side.
Gilles Chanteau
GileCAD
GitHub
bahman.jf.68
I don't want to call C# from Lisp,
I designed a form with C# .Net and user runs the form with command then filling the textboxes on the form. After clicking a button, all data (textboxe's values) should pass to a Lisp Function.
Suppose I have a Lisp Function like this :
(defun drawcircle (dm txt)
(setq pt (getpoint "Pick a point to add cricle")
(command "circle" pt "d" dm)
(command "text" "j" "mc" pt 2 0.0 txt)
There are two arguments in this function and this values should be run from C# with this values of the form. (The user enter diameter and the text on form)
_gile
To call a LISP function, you should use Application.Invoke() method. To make the function accessible, you have to use vl-acad-defun on the LISP side: (vl-acad-defun 'drawcircle).
var args = new ResultBuffer(
    new TypedValue((int)LispDataType.Text, "drawcircle"), // <- LISP function name
    new TypedValue((int)LispDataType.Double, double.Parse(textBoxDm.Text)), // <- dm argument
    new TypedValue((int)LispDataType.Text, textBoxTxt.Text)); // <- txt argument
Application.Invoke(args);
IMHO, trying to mix LISP and .NET is most of the time more complex and less robust than converting the LISP part into .NET.
Gilles Chanteau
GileCAD
GitHub
