ObjectIdCollection transform to new point in same drawing
manohar2375
Message 1 of 9
manohar2375
Hello Expertise,
Could you please help me with sample code to capture all ObjectIds within the Closed Polyline and transform/move them to new position at a time instead of one by one ObjectId in the same drawing. I know to transform one by one entity as below.
ent.TransformBy(Matrix3d.Displacement(new Vector3d(ptX, ptY, 0)));
But needs help to transform/move list of ObjectIds at a time in the same drawing.
Thanks in Advance.
Replies (8)
Message 2 of 9
_gile
Simply use  a foreach loop.
Gilles Chanteau
GileCAD
GitHub
Message 3 of 9
manohar2375
Hi _gile,
Thanks for your reply with suggestion.
But, Is there any possibility to transform list of ObjectIds at a time without use foreach or any other loop.
Thanks in Advance.
Message 4 of 9
Ed__Jobe
Put the foreach in a function method or an extension method and then it acts like a single step.
Ed
How to post your code.
Message 5 of 9
manohar2375
Hi Ed.Jobe,
Thanks for reply with suggestion.
But i am thinking that, drawing will get heavy load and get impact on performance if we use foreach, so thinking that, is there any other way to transform all at a time.
For Example:
to capture all elements, will use selection set as below.
PromptSelectionResult res = ed.SelectCrossingPolygon(pnt3dColl, filter);
so, like that, is there any other way.
Thanks in Advance.
Message 6 of 9
Ed__Jobe
Even if you found an AutoCAD api method that did it, how do you think they would do it? Somehow, at a base level, you have to process them one at a time. A foreach is the simplest method.
Ed
Message 7 of 9
essam-salah
for loop will be faster than foreach
            var ids = res.Value.GetObjectIds();
            int count = ids.Length;
            Entity entity;
            var transform = Matrix3d.Displacement(new Vector3d(0, 0, 0));
            for (int i = 0; i < count; i++)
                entity = ids[i].GetObject(OpenMode.ForWrite) as Entity;
                entity.TransformBy(transform);
Message 8 of 9
_gile
Are you sure about this ?
Did you test-it by yourself ?
If so, I should be interseted by how much faster is it ?
Rather than worrying about whether 'for' is faster than 'foreach', it is better to start by optimizing what you repeat at each iteration inside the loop.
A direct cast:
entity = (Entity)ids[i].GetObject(OpenMode.ForWrite);
is faster than a 'try cast' (which should only be used in conjunction with a : if (entity != null) ...
See this dicussion.
Gilles Chanteau
GileCAD
GitHub
Message 9 of 9
essam-salah
hi @_gile
thanks for the tip about Try Cast i always find smth helpful in your posts,
i tried both methods and here is the result:
Command:
Command: neltao
Unknown command "NELTAO".  Press F1 for help.
Command: NETLOAD
Command: FORVSFOREACH
 entities count: 62,389.00
  try cast:
        foreach1: 436.00
        forloop: 356.00
  without try cast:
        foreach2: 370.00
        forloop2: 362.00
  try cast:
        foreach1: 422.00
        forloop: 398.00
  without try cast:
        foreach2: 362.00
        forloop2: 365.00
  try cast:
        foreach1: 413.00
        forloop: 370.00
  without try cast:
        foreach2: 377.00
        forloop2: 351.00
  try cast:
        foreach1: 377.00
        forloop: 358.00
  without try cast:
        foreach2: 363.00
        forloop2: 402.00
  try cast:
        foreach1: 365.00
        forloop: 350.00
  without try cast:
        foreach2: 370.00
        forloop2: 373.00
        [CommandMethod("ForVsForeach")]
        public void ForAndForeach()
            #region curr doc
            var adoc = Application.DocumentManager.MdiActiveDocument;
            var adb = adoc.Database;
            var editor = adoc.Editor;
            var cdoc = cApp.CivilApplication.ActiveDocument;
            #endregion
            Stopwatch stopWatch = new Stopwatch();
            var ids = editor.SelectAll().Value.GetObjectIds();
            Entity entity;
            var transform = Matrix3d.Displacement(new Vector3d(22.22, 33.33, 0));
            editor.WriteMessage($"\n entities count: {count,0:#,0.00} \n");
            //////////////////////////////// try cast /////////////////////////////////////////////
            editor.WriteMessage($"\n\t try cast: \n");
            stopWatch.Reset();
            using (var tr = adb.TransactionManager.StartTransaction())
                stopWatch.Start();
                foreach (var id in ids)
                    entity = id.GetObject(OpenMode.ForWrite) as Entity;
                stopWatch.Stop();
                //tr.Commit();
            editor.WriteMessage($"\n\t\t\t foreach1: {stopWatch.ElapsedMilliseconds,0:#,0.00}\n");
            stopWatch.Reset();
                stopWatch.Start();
                stopWatch.Stop();
                //tr.Commit();
            editor.WriteMessage($"\n\n\t\t\t forloop: {stopWatch.ElapsedMilliseconds,0:#,0.00}\n");
            ////////////////////////////////without try cast/////////////////////////////////////////////
            editor.WriteMessage($"\n\t without try cast: \n");
            stopWatch.Reset();
                stopWatch.Start();
                    entity = (Entity)id.GetObject(OpenMode.ForWrite);
                stopWatch.Stop();
                //tr.Commit();
            editor.WriteMessage($"\n\n\t\t\t foreach2: {stopWatch.ElapsedMilliseconds,0:#,0.00}\n");
            stopWatch.Reset();
                stopWatch.Start();
                stopWatch.Stop();
                //tr.Commit();
            editor.WriteMessage($"\n\n\t\t\t forloop2: {stopWatch.ElapsedMilliseconds,0:#,0.00}\n\n");
