ObjectArx 2015 Wizard Not Installing
mgorecki
Message 1 of 9
mgorecki
I just downloaded the ObjectARXWizards-2015.zip file, extracted the ObjectARXWizards-2015 folder and ran the msi.
In the folder it created there is one folder "inc".  Inside that folder are two files crx.props and rxsdk_common.props.  That's all.
The only thing different I do is change the folder name from ObjectARX to ObjectARX 2015 in the setup dialog box.
I'm sure there needs to be more folders and more files than these two.
Can anyone help me out?
Mark
Replies (8)
Message 2 of 9
_gile
Please specify: do you want to install the ObjectARX 2015 Wizzard (which is mainly a wizard to create ObjectARX C++ templates in Visual Studio) or the ObjectARX SDK which contains ObjectARX and .NET libraries, docs, samples.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 9
Alexander.Rivilis
@mgorecki
1. You selected wrong forum for this question. About ObjectARX (Wizard) you have to ask here: https://forums.autodesk.com/t5/objectarx/bd-p/34
2. You have to install ObjectARX Wizard with Administrator rights and with disable UAC:
https://forums.autodesk.com/t5/objectarx/objectarx-2015-wizard/m-p/5952746/highlight/true#M33343
https://forums.autodesk.com/t5/objectarx/objectarx-2015-wizard-i-gave-up/m-p/5108906/thread-id/31607...
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 4 of 9
mgorecki
Hi Gilles,
I want to use ObjectARX SDK for VB.Net.  I can't seem to find a downloadable for AutoCAD 2015 for Windows, just Mac.
Mark
Message 5 of 9
Alexander.Rivilis
@mgorecki wrote:
Hi Gilles,
Mark
ObjectARX SDK 2015:
http://download.autodesk.com/esd/objectarx/2015/Autodesk_ObjectARX_2015_Win_64_and_32_Bit.exe
Expert Elite Member
Message 6 of 9
mgorecki
Hi Alexander,
Thank you very much.  I really appreciate your help.
Best regards,
Mark
Message 7 of 9
_gile
No luck. Autodesk just keep the 4 latest version, 2015 should have been removed when they added 2018 some days ago.
I've seen a message from @Alexander.Rivilis somewhere around here with links to older versions of ObjectaRX SDKs.
Edit:
Oops!... Too late...
Gilles Chanteau
GileCAD
GitHub
Message 8 of 9
Alexander.Rivilis
Previous versions of ObjectARX SDK since R14: https://forums.autodesk.com/t5/programmirovanie-objectarx-arx/objectarx-sdk-starye-i-novye-versii/td... (first column in table is a version of SDK, second column - url for download, third column - Visual Studio version for "native" compiler/linker)
Expert Elite Member
Message 9 of 9
mgorecki
Thank you both for your help.
