JavaScript API
JavaScript API
kerry_w_brown
Advisor Advisor
JavaScript API
kerry_w_brown
Hi all,
Can anyone point to towards any use case examples to justify learning the  JavaScript API ??
I was asked this today by a client and was unable to justify the effort or, in fact, even explain any uses for it.
Kerry
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
_gile
Hi Kerry,
I never used it, but I remember Kean Walmsley posted some pages about AutoCAD JavaScript API.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
kerry_w_brown
Yep, about 10 years ago I think. I'll see if they can help.
jose_coimbras1
Hi.
I used some weeks ago. I can do something like a palette with buttons. Is relativity easy to do the code. The minus/bottom of all is lack of reallife examples, even in the internet. It does not interact with the DWG database (or i cannot do it), as example, read coordinates of a polyline... But can draw new entities with a OSNAP etc..
Search mya name in blogs you can find some use cases i done.
I think the API is almost the same since 2014...
Ed__Jobe
There has never been much development with JavaScript api. You may be interested in the python api. Daniel over at theSwamp has done a lot with it. He's created a wrapper for the arx/C++ api's.
Ed
How to post your code.
jose_coimbras1
When needed i go to C# ...
