issue with .fas file not loading when new Drawing is opened
Domzinator
Domzinator
Hi all its mt first time using the PackageContents.xml method to load plugins into autocad. the issue i am facing is that my .fas file doesnt load every time a new drawing is opened. have i done anything wrong? here is  my PackageContents.xml
<?xml version="1.0" encoding="utf-8"?>
<ApplicationPackage
    SchemaVersion="1.0"
    AppVersion="1.0.0"
    ProductType="Application"
    Author="AutomateX"
    ProductCode="{BCE3E73A-9205-424F-900E-39B2EF4973AA}"
    Name="MyCivil3D"
    Description="Automation Suite For Civil 3D"
    Icon="./Contents/Resources/Icons/MyCivil3D_Button_Image Full.png"
    HelpFile="">
  <CompanyDetails
      Name="AutomateX"
      Email="Support@automatex.co.za"
      Website="http://www.automatex.co.za" />
  <Components>
    <RuntimeRequirements
        SupportPath="./Contents/Support"
        OS="Win64"
        SeriesMin="R25.0"
        SeriesMax="R25.0"
        Platform="Civil3D" />
    <ComponentEntry
        AppName="AutomateX_MyCivil3D"
        Version="1.0.0"
        AppDescription="Automation Suite For Civil 3D"
        ModuleName="./Contents/Main/AutomateX_MyCivil3D_2025.dll"
        LoadOnAutoCADStartup="True"
        LoadOnCommandInvocation="True" />
    <ComponentEntry
        AppName="MyCivil3D_SystemCmd"
        Version="1.0.0"
        AppDescription="System Command LISP File for MyCivil3D"
        ModuleName="./Contents/Main/MyCivil3D_Systemcmd.fas"
        PerDocument="True"
  </Components>
</ApplicationPackage>
Civil 3D Certified Professional
_gile
You should not have both:
because it is either "LoadOnAutoCADStartup" or "LoadOnCommandInvocation". In the second case, you should have a <Commands> node.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Domzinator
than you i will remove the one i dont need
