Interaction between userform and model space
Hi All,
How can we made interactive between user form button and model space? When I click a button in user form, it needs me to click the model space first. Only after that the task will begin.
I want it to be like what autocad have. Click on the button and directly begin the work in the model space, without needing to click the model space first.
Here is my code :
User Form setting :
Public Class UICall
    Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
    Friend Shared AcPs As Autodesk.AutoCAD.Windows.PaletteSet = Nothing
    Private UIClass As LogicUI = Nothing
    <CommandMethod("LogicUI")> _
    Public Sub CallLogicUserInterface()
        If AcPs = Nothing Then
            AcPs = New Autodesk.AutoCAD.Windows.PaletteSet("Logic User Interface", New Guid("{3AD1B2B3-8194-4FA9-B91E-91BBB45279E3}"))
            AcPs.Style = Autodesk.AutoCAD.Windows.PaletteSetStyles.ShowCloseButton
            UIClass = New LogicUI
            AcPs.Add("Logic UI", UIClass)
            AcPs.Size = New Drawing.Size(200, 700)
        End If
        AcPs.Visible = False : AcPs.Visible = True
        AcPs.WindowState = Autodesk.AutoCAD.Windows.Window.State.Normal
        AcPs.Dock = Autodesk.AutoCAD.Windows.DockSides.Left
    End Sub
    Public Sub Initialize() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Initialize
    End Sub
    Public Sub Terminate() Implements Autodesk.AutoCAD.Runtime.IExtensionApplication.Terminate
        AcPs = Nothing
        AcPs.Dispose()
    End Sub
End Class
Click Event in the userform :
    Private Sub Button4_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button4.Click
        Dim cl As Class1 = New Class1
        cl.CreateLine()
    End Sub
Cad function :
Public Sub CreateLine()
        Dim ed As Editor = App.DocumentManager.MdiActiveDocument.Editor
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Using tr As Transaction = db.TransactionManager.StartTransaction
            Dim ppr As PromptPointResult = ed.GetPoint(vbLf & "Specify base point")
            Dim pt1 As Point3d = ppr.Value
            ppr = ed.GetPoint(vbLf & "Specify next point")
            Dim pt2 As Point3d = ppr.Value
            Dim acLine As Line = New Line(pt1, pt2)
            Dim btr As BlockTableRecord = tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite)
            btr.AppendEntity(acLine)
            tr.AddNewlyCreatedDBObject(acLine, True)
            tr.Commit()
        End Using
    End Sub
Balaji_Ram
Hello Abu,
Please try this :
http://adndevblog.typepad.com/autocad/2013/03/use-of-windowfocus-in-autocad-2014.html
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Keith.Brown
I would also add that it might be better if you put your logic to draw the line inside of a command and then have your button call the command.  This will give your power users the opportunity to use the keyboard instead of using your form if they want.
@Balaji_Ram wrote:
Hello Abu,
Please try this :
Balaji
Hi Balaji,
This use for Autocad 2014 and above. Mine is 2013 version.
Sorry not inform this before
  Thanks for the idea keith. I'll do it that way then
