How to use GetBoundingBox ?
JanneTS
JanneTS
I have a C# Navisworks 2016 plugin that uses Autocad 2016 automation. I read a handle string of an entity from Navisworks and get the corresponding object in autocad with
Autodesk.AutoCAD.Interop.Common.AcadObject ThePart = TheDoc.HandleToObject(HandleToZoom);
then I try to get the bounding box of the entity with
Autodesk.AutoCAD.Interop.Common.AcadEntity TheEnt = (Autodesk.AutoCAD.Interop.Common.AcadEntity)ThePart;
object a;
object b;
TheEnt.GetBoundingBox(out a, out b);
but the GetBoundinBox throws an exception 8020001C
Late binding doesn’t work either,
double[] aMinPoint = new double[3], aMaxPoint = new double[3];
object[] Params = new object[] { aMinPoint, aMaxPoint };
TheEnt.GetType().InvokeMember("GetBoundingBox", System.Reflection.BindingFlags.InvokeMethod, null, TheEnt, Params);
throws an exception too.
How to use the GetBoundingBox correctly?
Norman_Yuan
Following code, using COM API in a .NET add-in command method, works OK with my AutoCAD2015/2016:
public class Commands
        [CommandMethod("BBox")]
        public static void DoDocumentCommand()
            Document dwg = CadApp.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            try
                //Get COM object: AcadDocument
                AcadDocument doc = (AcadDocument)Autodesk.AutoCAD.ApplicationServices.DocumentExtension.GetAcadDocument(dwg);
                //Select an entity
                object ent;
                object point;
                doc.Utility.GetEntity(out ent, out point, "\nSelect an entity:");
                ed.WriteMessage("\nSelected entity is: {0}", (ent as AcadEntity).EntityName);
                //Get AcadEntity's bounding box
                object minPt;
                object maxPt;
                (ent as AcadEntity).GetBoundingBox(out minPt, out maxPt);
                ed.WriteMessage("\nMin point: {0}, {1}", (minPt as double[])[0], (minPt as double[])[1]);
                ed.WriteMessage("\nMax point: {0}, {1}", (maxPt as double[])[0], (maxPt as double[])[1]);
            catch (Autodesk.AutoCAD.Runtime.Exception aex)
                ed.WriteMessage("\nError: {0}", aex.Message);
                ed.WriteMessage("\n*Cancel*");
            catch (System.Exception ex)
                ed.WriteMessage("\nError: {0}", ex.Message);
            finally
                Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
Norman Yuan
Drive CAD With Code
JanneTS
Thanks. My problem still remains though. Now I have noticed that the exception happens only in case of 3rd party custom objects. I wonder if it's a bug or a feature that GetBoundingBox fails with custom objects?
However, I don't really need the bounding box after all, I need the part location in WCS. How to get the location of an entity via COM API, if I know it's handle?
