I want to override the dimension Text with keeping the tolerances as it is
varad.keshatwar
Message 1 of 9
varad.keshatwar
I want to override the dimension Text, with keeping the tolerances as it is. Is it possible?
Replies (8)
Message 2 of 9
_gile
You can get the dimension MText contents from the BlockTableRecord of the Dimension and the measurement text from the dimension properties.
Here's an example you can start from.
        private static string GetDimensionContents(Dimension dimension) =>
            ((BlockTableRecord)dimension.DimBlockId.GetObject(OpenMode.ForRead))
            .Cast<ObjectId>()
            .Where(id => id.ObjectClass.Name == "AcDbMText")
            .Select(id => (MText)id.GetObject(OpenMode.ForRead))
            .First()
            .Contents;
        private static string GetMeasurementText(Dimension dimension) =>
            (dimension is LineAngularDimension2 || dimension is Point3AngularDimension) ?
            Converter.AngleToString(dimension.Measurement, (AngularUnitFormat)dimension.Dimaunit, dimension.Dimadec) :
            Converter.DistanceToString(dimension.Measurement, (DistanceUnitFormat)dimension.Dimlunit, dimension.Dimdec);
And then use Regex to replace the measurement part by another text.
dimension.DimensionText = Regex.Replace(
    GetDimensionContents(dimension),
    GetMeasurementText(dimension),
    replacementText);
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 9
varad.keshatwar
Hii @_gile
I'm using Stacked Dimension to override the tolerances. I'm overriding the text as follows
\A1;%%c316{\H0.5x;\S+0.00^-0.36;
by overriding dimension text as above, I get the following result
Message 4 of 9
_gile
Sorry, I don't understand what you're trying to do.
Please post a 'before/after' example.
Gilles Chanteau
GileCAD
GitHub
Message 5 of 9
a.kouchakzadeh
Giles, could you possible explain in a step by step manner how does thank LINQ work?
Message 6 of 9
_gile
            .Cast<ObjectId>()
            .First()
            .Contents;
stands for:
            string contents = null;
            var btr = (BlockTableRecord)dimension.DimBlockId.GetObject(OpenMode.ForRead);
            foreach (ObjectId id in btr)
                if (id.ObjectClass.Name == "AcDbMText")
                    var mtext = (MText)id.GetObject(OpenMode.ForRead);
                    contents =  mtext.Contents;
                    break;
            return contents;
Gilles Chanteau
GileCAD
GitHub
Message 7 of 9
varad.keshatwar
@_gile
Attaching the before and after images FYI
Before Image
After Overriding the Text, I achieved the following results
After Image
Message 8 of 9
_gile
It's still confusing. From what I see it is not "keeping the tolerance intact".
If I stick to your request: "override the dimension Text with keeping the tolerances as it is", my first answer is correct.
        [CommandMethod("TEST")]
        public void Test()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var promptEntityOptions = new PromptEntityOptions("\nSelect Dimension: ");
            promptEntityOptions.SetRejectMessage("\nSelected object is not a Dimension.");
            promptEntityOptions.AddAllowedClass(typeof(Dimension), false);
            var promptEntityResult = ed.GetEntity(promptEntityOptions);
            if (promptEntityResult.Status != PromptStatus.OK) return;
            using (var tr = db.TransactionManager.StartTransaction())
                var dimension = (Dimension)tr.GetObject(promptEntityResult.ObjectId, OpenMode.ForWrite);
                string currentMeasurementText = GetMeasurementText(dimension);
                var promptResult = ed.GetString(
                    $"\nCurrent mesurement = {currentMeasurementText}." +
                    "\nEnter the replacement text: ");
                if (promptResult.Status == PromptStatus.OK)
                    string replacementText = promptResult.StringResult;
                        currentMeasurementText,
                        replacementText);
                tr.Commit();
            .Cast<ObjectId>()
            .First()
            .Contents;
(view in My Videos)
Gilles Chanteau
GileCAD
GitHub
Message 9 of 9
varad.keshatwar
@_gile
There was Some mistake from my side, I actually attached some other image. I've updated the images please check
