Howto get Space / Layout of object(id)
faceter
faceter
how can I get the Layout of an existing Entity (e.g. AttributeReference entity) ?
I have the AttributeReference object and can get it's ObjectID.
Is there a property or function to get the Layout of the object?
Thanks a lot for your help
nil
_gile
You can use the BlockId property of the entity to get ObjectId of the BlockTableRecord instance which owns the entity. It can be either a layout or a block definition.
If you need the Layout instance, you can check if its IsLayout property equals true and, then, get the Layout object with the BlockTableRecord.LayoutId property.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
faceter
Thanks a lot
works fine.
nil
BKSpurgeon
using (Transaction tr = db.TransactionManager.StartTransaction())
    Entity entity = tr.GetObject(id, OpenMode.ForRead) as Entity;
    BlockTableRecord btr = tr.GetObject(entity.BlockId, OpenMode.ForRead) as BlockTableRecord;
    if (btr.IsLayout)
    else
    tr.Commit();
some code demonstrating the above for a quick cut and paste.
All credit to Gilles for the answer.
