How to get registry key of running instance of AutoCAD
Ed__Jobe
Mentor Mentor
Ed__Jobe
I need to get HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R22.0\ACAD-1007:409\FixedProfile\General of the current instance of acad. The problem is that the section in blue can vary, for my app can run in multiple versions of acad. I can't use the exe path as an indication because that remains in "c:\program files\autodesk\autocad 2018" regardless of the vertical app. Is there a direct way of determining the proper key for FixedProfile?
Ed
How to post your code.
_gile
Whate about using HostApplicationServices.UserRegistryProductkey?
Gilles Chanteau
GileCAD
GitHub
_gile
If you need to get AutoCAD registry keys from outside AutoCAD, you can see the little AutocadRegistryServices library at TheSwamp.
Gilles Chanteau
GileCAD
GitHub
Ed__Jobe
Thanks Gilles, that was exactly what I needed.
Ed
