How to insert an Image file into an Ole2Frame
Could anybody please show me how to insert a jpg file in the autocad drawing file using an Ole2Frame.
I need to show  a logo in the drawing which is embedded (not linked) in the dwg.
Thanks for your help.
Peter
Do you know your questions resolution thanks
Balaji_Ram
It is not possible for applications to create an ole object (AcDbOle2Frame/Ole2Frame object) in AutoCAD.
This is explained in the ObjectARX help file in the description for “setOleObject” method and I quote :
“The COleClientItem class used by AutoCAD is a modified version of the class that ships from Microsoft. This means that it is not possible for applications to create their own COleClientItem objects for use by this function. This function can only be used with COleClientItem objects created by AutoCAD (that is, the object from another AcDbOle2Frame object).“
For this reason, the workaround could be to use a drawing file that contains the image as a template and using it in an insert operation.
If it is just an image in the drawing that you want to insert (not a Ole2Frame), you may find this blog post helpful :
http://adndevblog.typepad.com/autocad/2012/05/how-to-insert-a-rasterimage-using-the-net-api.html
Balaji
Developer Technical Services
Autodesk Developer Network
