SendCommand from palette button retaining preselected object(s)
SRSDS
Advisor Advisor
SRSDS
Hi, Hope someone can help here..
I have a palette with a button. I'd like to be able to repeat the button command if space or enter is pressed.
But I also may have preselected objects to base the command on (otherwise it needs a pickfirst selection).
For some reason SendStringToExecute clears the current selectionset and I need to reselect an entity.
While calling the Sub directly doesn't allow the command to be repeated and ignores the DR CommandMethod call.
Is there another way to achieve this?
    Private Sub btnDraw_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnDraw.Click
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim mycommands As New Commands
        mycommands.Draw()
        'doc.SendStringToExecute("DR ", True, False, True)
    End Sub
    <CommandMethod("DR")> _
    Sub Draw()
'If selectedobjects.count>0 then ...
    End Sub
Alfred.NESWADBA
It will not clear the pickfirstselectionset if you tell to hold it ... within the command-attribute "UsePickSet":
<CommandMethod("DR", Autodesk.AutoCAD.Runtime.CommandFlags.UsePickSet)> _
Sub Draw()
End Sub
So you can do SendCommand for the commands to be repeatable by user <ENTER>
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
SRSDS
That was quick...Works!
Thanks again!!
