how to end a prompting select entity operation ?
giser828DUHJV
giser828DUHJV
my modeless dialog has two buttons,  the first button clicked to prompt select  an entity,
if the second button clicked , i want to end the prompting select entity first and then  do other things,
how  to  end the prompting select entity  operation in the second button click event ?
ActivistInvestor
You can use the Document's SendStringToExecute() method to send an escape sequence to the command line.
giser828DUHJV
doc.SendStringToExecute("\x03\x03", false, true, false);   ?
// this operation will change the entities selected state
ActivistInvestor
Yes, it will deselect entities.  The only other option is to add a keyword to your prompt, and issue the keyword using SendStringToExecute().
