Getting fatal error access violation when using WblockCloneObjects to clone blocks from another drawing database.
ShricharanaB
ShricharanaB
I've created a C# .NET plugin for autocad which adds a command. I have has a macro in an excel file which starts autocad and runs the plugin command which gets the input through excel file and then creates what is required.
The plugin needs to import blocks from another drawing and I'm using WblockCloneObjects to do this.
I've used the same import code till now without any issues.
When I run the macro through excel I'm randomly getting fatal error access violation error with autocad crashing at WblockCloneObjects line. This happens randomly when starting through excel macro. (Happened only once in debug mode, can't replicate the error again in debug mode.)
I'm using AutoCAD mechanical 2020.
In excel, I've reference AutoCAD 2019 Type Library(can't find for 2020) and AutoCAD Mechanical 2020 Type Library.
Can any one please help?
I'm attaching the error details, the import code and application starting code below.
Error shown from the dump file:
Call stack:
Full first line in call stack:
> Acdbmgd.dll!Autodesk.AutoCAD.DatabaseServices.Database.WblockCloneObjects(Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection identifiers, Autodesk.AutoCAD.DatabaseServices.ObjectId id, Autodesk.AutoCAD.DatabaseServices.IdMapping mapping, Autodesk.AutoCAD.DatabaseServices.DuplicateRecordCloning cloning, bool deferTranslation) Line 6207 C#
Import Method being used:
/// <summary>
/// Checks if given block names exist in given block table and imports all blocks from given drawng if not.
/// </summary>
/// <param name="blockNamesToCheck">Array of block names to check.</param>
/// <param name="drawingPaths">import location of the blocks.</param>
public static void ImportBlocks(string[] blockNamesToCheck, string sourceFileName)
    DocumentCollection dm = Application.DocumentManager;
    Editor ed = dm.MdiActiveDocument.Editor;
    Database destDb = dm.MdiActiveDocument.Database;
    Database sourceDb = new Database(false, true);
    //string sourceFileName;
    if (!ShouldImport(destDb, blockNamesToCheck))
        return;
    try
        // Read the DWG into a side database
        sourceDb.ReadDwgFile(sourceFileName, FileOpenMode.OpenForReadAndAllShare, false, null);
        // Create a variable to store the list of block identifiers
        ObjectIdCollection blockIds = new ObjectIdCollection();
        Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = sourceDb.TransactionManager;
        using (Transaction myT = tm.StartTransaction())
            // Open the block table
            BlockTable bt = (BlockTable)tm.GetObject(sourceDb.BlockTableId, OpenMode.ForRead, false);
            // Check each block in the block table
            foreach (ObjectId btrId in bt)
                BlockTableRecord btr = (BlockTableRecord)tm.GetObject(btrId, OpenMode.ForRead, false);
                // Only add named & non-layout blocks to the copy list
                if (!btr.IsAnonymous && !btr.IsLayout) blockIds.Add(btrId);
                btr.Dispose();
        // Copy blocks from source to destination database
        IdMapping mapping = new IdMapping();
        sourceDb.WblockCloneObjects(blockIds, destDb.BlockTableId, mapping, DuplicateRecordCloning.Replace, false);
        // ed.WriteMessage("\nCopied " + blockIds.Count.ToString() + " block definitions from " + sourceFileName + " to the current drawing.");
        ed.WriteMessage("Blocks imported.");
    catch (Autodesk.AutoCAD.Runtime.Exception ex)
        ed.WriteMessage("\nError during copy: " + ex.Message);
        throw new Exception(ex.Message);
    sourceDb.Dispose();
VBA code in Excel Macro:
Dim ACAD As AcadApplication
Dim NewFile As Object
Dim MyAcadPath As String
Dim bReadOnly As Boolean
    On Error Resume Next
    Set ACAD = GetObject(, "autocad.Application")
    If (Err <> 0) Then
        Err.Clear
        Set ACAD = CreateObject("autocad.Application")
        If (Err <> 0) Then
            MsgBox "Could Not Load AutoCAD!", vbExclamation
            End
    ACAD.Visible = True
    MyAcadPath = "C:\Autodesk\Drawing.dwg"
    bReadOnly = True
    Set NewFile = ACAD.Documents.Open(MyAcadPath, bReadOnly)
    Call CreateInputString
    NewFile.SendCommand cmd
References being used in excel macro
I would really appreciate any help.
Thanks in advance!!!
ShricharanaB
Hi all,
I still haven't been able to solve this issue. Has anyone any idea?
Thanks in advance for any help.
