I'm also having the same problem but in pure model space (tilemode=1). Also, after including the code in my project, the plugin made autocad run very slow. very strange. I will include the code below. Thanks in advance Mr. Chanteau, or whoever else helps! Also, how do I create that code window that you have your code example in above?
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
namespace ArchitecturalWindows
public class UCSCommands
private static ObjectId previousUcsId = ObjectId.Null; // Store the previous UCS ObjectId
private static bool wasWorldUCS = true; // Track if the previous UCS was World UCS
public static void SetNewUCS()
Document doc = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction tr = db.TransactionManager.StartTransaction())
// Get the UCS table
UcsTable ucsTable = tr.GetObject(db.UcsTableId, OpenMode.ForRead) as UcsTable;
// Get the current viewport settings
ObjectId viewportId = db.CurrentViewportTableRecordId;
ViewportTableRecord vpRecord = tr.GetObject(viewportId, OpenMode.ForWrite) as ViewportTableRecord;
previousUcsId = vpRecord.UcsName;
// Store the current UCS
if (ucsTable.Has(vpRecord.UcsName))
wasWorldUCS = false;
else
wasWorldUCS = true;
// Define a new UCS
string ucsName = "MyNewUCS";
UcsTableRecord newUcs;
if (ucsTable.Has(ucsName))
newUcs = tr.GetObject(ucsTable[ucsName], OpenMode.ForRead) as UcsTableRecord;
else
ucsTable.UpgradeOpen();
newUcs = new UcsTableRecord
Name = ucsName,
Origin = new Point3d(10, 10, 0), // Example new origin
XAxis = new Vector3d(0, 0, 1),
YAxis = new Vector3d(0, 1, 0)
ucsTable.Add(newUcs);
tr.AddNewlyCreatedDBObject(newUcs, true);
// Set the new UCS to the viewport
vpRecord.SetUcs(newUcs.ObjectId);
vpRecord.UcsSavedWithViewport = true; // Mark UCS as saved with this viewport
tr.Commit();
ed.WriteMessage("\nNew UCS set as current.");
