How to change UCS for model space inside viewport ?
nghiabt04
nghiabt04
Currently, I want to change UCS of model space in viewport but don't know how to do.
I found the method
.SetUcs()
 but it's not working.
Does anyone knows to do it, please advise me.
Thanks and Regards.
_gile
The Viewport type has a Ucs read/write property.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
nghiabt04
Hi @_gile,
I also try this but see nothing change.
_gile
Most often when dealing with viewport, we need to swich them off and on to update the changes.
Try this way:
vp.On = false;
vp.Ucs = ucs;
vp.On = true;
Gilles Chanteau
GileCAD
GitHub
ivanstarr3
I'm also having the same problem but in pure model space (tilemode=1).  Also, after including the code in my project, the plugin made autocad run very slow.  very strange.  I will include the code below.  Thanks in advance Mr. Chanteau, or whoever else helps!  Also, how do I create that code window that you have your code example in above?
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
namespace ArchitecturalWindows
public class UCSCommands
private static ObjectId previousUcsId = ObjectId.Null; // Store the previous UCS ObjectId
private static bool wasWorldUCS = true; // Track if the previous UCS was World UCS
public static void SetNewUCS()
Document doc = Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor ed = doc.Editor;
using (Transaction tr = db.TransactionManager.StartTransaction())
// Get the UCS table
UcsTable ucsTable = tr.GetObject(db.UcsTableId, OpenMode.ForRead) as UcsTable;
// Get the current viewport settings
ObjectId viewportId = db.CurrentViewportTableRecordId;
ViewportTableRecord vpRecord = tr.GetObject(viewportId, OpenMode.ForWrite) as ViewportTableRecord;
previousUcsId = vpRecord.UcsName;
// Store the current UCS
if (ucsTable.Has(vpRecord.UcsName))
wasWorldUCS = false;
else
wasWorldUCS = true;
// Define a new UCS
string ucsName = "MyNewUCS";
UcsTableRecord newUcs;
if (ucsTable.Has(ucsName))
newUcs = tr.GetObject(ucsTable[ucsName], OpenMode.ForRead) as UcsTableRecord;
else
ucsTable.UpgradeOpen();
newUcs = new UcsTableRecord
Name = ucsName,
Origin = new Point3d(10, 10, 0), // Example new origin
XAxis = new Vector3d(0, 0, 1),
YAxis = new Vector3d(0, 1, 0)
ucsTable.Add(newUcs);
tr.AddNewlyCreatedDBObject(newUcs, true);
// Set the new UCS to the viewport
vpRecord.SetUcs(newUcs.ObjectId);
vpRecord.UcsSavedWithViewport = true; // Mark UCS as saved with this viewport
tr.Commit();
ed.WriteMessage("\nNew UCS set as current.");
_gile
The Database.CurrentViewportTableRecordId property is not reliable because it does not update correctly.
To set a new UCS in the current viewport, you can simply set the Editor.CurrentCoordinateSystem property.
public static void SetUCS(Point3d origin, Vector3d xAxis, Vector3d yAxis)
    var zAxis = xAxis.CrossProduct(yAxis);
    Application.DocumentManager.MdiActiveDocument.Editor.CurrentUserCoordinateSystem =
        Matrix3d.AlignCoordinateSystem(
            Point3d.Origin, Vector3d.XAxis, Vector3d.YAxis, Vector3d.ZAxis,
            origin, xAxis.GetNormal(), yAxis.GetNormal(), zAxis.GetNormal());
1. Hit the "Expand toolbar" button:
2. Hit the "Insert/Edit code sample" button:
3. Choose the language and past the code:
Gilles Chanteau
GileCAD
GitHub
ivanstarr3
Wow thanks Mr. Chanteau!  So fast a response!
