Get Precision for Text Value
traiduong014969
traiduong014969
Hi all,
Recently, I how to learn get Coordinate value from click by mouse. However, the value that i receive has many number behind "." . So I want to get a number that precision is ".00". For example Point 1 (5.23, 6.45, 5,77)
NOT ((5.23434645, 6.45463463456, 5.77xxx-xxxxxxxx). You can see the snapshot below:
Someone can help me edit again this code
Thank you !
[CommandMethod("11GetPoint")]
        public void 11GetPoint()
            Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
            PromptPointOptions pr = new PromptPointOptions("Click mouse to get point");
            pr.AllowNone = true;
            pr.AllowArbitraryInput = true;
            PromptPointResult kq = ed.GetPoint(pr);
            if (kq.Status != PromptStatus.OK) return;
            pr.BasePoint = kq.Value;
            pr.UseBasePoint = true;
            PromptResult kq1 = ed.GetPoint(pr);
            if (kq1.Status != PromptStatus.OK) return;
            ed.WriteMessage("\np1 = " + kq.Value.ToString() + "p2 = " + kq1.ToString());
Jeff_M
Use the Fixed-point formatting: ToString("F2")
See THIS for more on string formatting.
Jeff_M, also a frequent Swamper
_gile
The Point3d structure implements IFormatable so you can pass a format to the ToString method (this requires to also pass a FormatProvider)
    + kq.Value.ToString("0.00", CultureInfo.CurrentCulture)
    + "p2 = "
    + kq1.Value.ToString("0.00", CultureInfo.CurrentCulture));
This can be simplified using the overload of Editor.WriteMessage method which takes a params object[] argument(s).
ed.WriteMessage("\np1 = {0:0.00} p2 = {1:0.00}", kq.Value, kq1.Value);
Or the (not so) new string interpolation using $.
ed.WriteMessage($"\np1 = {kq.Value:0.00} p2 = {kq1.Value:0.00}");
Gilles Chanteau
GileCAD
GitHub
traiduong014969
Thanh you @_gile@Jeff_M .
This working fine.
