How to catch Save/Quit Document?
JanetDavidson
Message 1 of 10
JanetDavidson
Hello Experts,
I have a routine which listen to Save Document command and then write  some Data to Document Dictionary.
The problem  is when user click on top right 'X' to quit and then when Auto-CAD prompts for saving , my routine crashes.
What is the best approach to catch if user clicks the 'X' and if user wants to save the document before document closes  data to be written to Dictionary?
Thanks in Advance.
Janet.
Replies (9)
Message 2 of 10
_gile
You should try to handle the Document.BeginDocumentClose envent.
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 10
JanetDavidson
Hello Gile and Thank you  for replying back to me.
If I use that Event how would I know if user is pressing Yes or No when program asking " Save Change to C:\BlahBlah.dwg ?"
I don't want to save database if user pressing No.
I summarized the code below for your review.
Public Class AllCommandAndInitialize
    Implements Autodesk.AutoCAD.Runtime.IExtensionApplication
    Public Sub Initialize() Implements IExtensionApplication.Initialize
        AddHandler Application.DocumentManager.DocumentCreated, AddressOf StartUpEvents.On_Document_Created
    End Sub
    Public Sub Terminate() Implements IExtensionApplication.Terminate
    End Sub
    Class StartUpEvents
        Shared Sub On_Document_Created(sender As Object, e As DocumentCollectionEventArgs)
            AddHandler Application.DocumentManager.CurrentDocument.BeginDocumentClose, AddressOf StartUpEvents.OnBeginDocumentClose
        End Sub
        Shared Sub OnBeginDocumentClose(sender As Object, e As DocumentBeginCloseEventArgs)
            'If user presses 'Yes' to "Save c:\blahblah.dwg"   then
            '       draw a line and save database.
            'else
            '      do nothing.
            ' end if
        End Sub
    End Class
End Class
Message 4 of 10
_gile
You can handle the Database.BeginSave or the Database.SaveComplete event
    public class Initialization : IExtensionApplication
        public void Initialize()
            var docMan = Application.DocumentManager;
            docMan.DocumentCreated += DocumentManager_DocumentCreated;
            foreach (Document doc in docMan)
                doc.Database.SaveComplete += Database_SaveComplete;
        private void DocumentManager_DocumentCreated(object sender, DocumentCollectionEventArgs e)
            e.Document.Database.SaveComplete += Database_SaveComplete;
        private void Database_SaveComplete(object sender, DatabaseIOEventArgs e)
            // do your stuff here
        public void Terminate()
Gilles Chanteau
GileCAD
GitHub
Message 5 of 10
JanetDavidson
Thanks for your time and expertise.
Cheers,
Janet.
Message 6 of 10
mhillis
@_gile
I apologize for hijacking, but this is 'very' close in topic to a thread I was going to make.
So lets say a user is Closing/Saving a DWG,  we can catch that with the event handlers.  But utilizing those event handlers, is there anyway to stop the DWG from closing if we wanted to within that Event Handler?
Message 7 of 10
_gile
As explained in the docs, if you handle Document.DocumentBeginClose event, you "can call DocumentBeginCloseEventArgs.Veto() during this notification to stop AutoCAD from shutting down the document."
Gilles Chanteau
GileCAD
GitHub
Message 8 of 10
mhillis
Thanks for the quick reply!  I should have specified this further in my initial post, but I do want to be able to veto the close after the save has been performed.  I'll need to look  into it and mess around with it.
Message 9 of 10
JanetDavidson
Hello Gile
I am not sure why this don't work. I followed what you suggested.
still I don't see what I expect to see. I click on 'X' and when get prompt to save, I say save. after opening the DWG file I don't see the line in there. Would you mind please.
    End Sub
    End Sub
    Class StartUpEvents
        End Sub
                AddHandler Application.DocumentManager.MdiActiveDocument.Database.SaveComplete, AddressOf OnSaveComplete
            End Sub
            Private Shared Sub OnSaveComplete(sender As Object, e As DatabaseIOEventArgs)
                Dim Mydwg As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
                Dim MyDb As Database = Mydwg.Database
                Using MyDb
                    Using tr As Transaction = MyDb.TransactionManager.StartTransaction
                        Try
                            Dim mybtr As BlockTableRecord = CType(tr.GetObject(MyDb.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord)
                            Dim myline As Line = New Line(New Point3d(0, 0, 0), New Point3d(10000, 10000, 0))
                            mybtr.AppendEntity(myline)
                            tr.AddNewlyCreatedDBObject(myline, True)
                            tr.Commit()
                            Autodesk.AutoCAD.ApplicationServices.DocumentExtension.CloseAndSave(Mydwg, Mydwg.Name)
                        Catch ex As Autodesk.AutoCAD.Runtime.Exception
                            MsgBox(ex.StackTrace)
                        End Try
                    End Using
                End Using
            End Sub
        End Class
    End Class
Message 10 of 10
_gile
It looks like the Document.BeginDocumentClose event fires after the database have been saved.
You can try handling the Database.BeginSave event and check if the current command is "CLOSE".
            var docs = Application.DocumentManager;
            foreach (Document doc in docs)
                doc.Database.BeginSave += Database_BeginSave;
            docs.DocumentCreated += Docs_DocumentCreated;
        private void Docs_DocumentCreated(object sender, DocumentCollectionEventArgs e)
            e.Document.Database.BeginSave += Database_BeginSave;
        private void Database_BeginSave(object sender, DatabaseIOEventArgs e)
            var db = (Database)sender;
            var doc = Application.DocumentManager.GetDocument(db);
            if (doc.CommandInProgress == "CLOSE")
                using (var tr = db.TransactionManager.StartOpenCloseTransaction())
                    var ms = (BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite);
                    var line = new Line(Point3d.Origin, new Point3d(1000.0, 1000.0, 0.0));
                    ms.AppendEntity(line);
                    tr.AddNewlyCreatedDBObject(line, true);
                    tr.Commit();
Gilles Chanteau
GileCAD
GitHub
