Updating an Excel spreadsheet from a linked AutoCAD table using .NET
jayhar
Advisor Advisor
jayhar
How can insert this code in AutoCAD?
Here's the C# code:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Windows;
namespace LinkToExcel
  public class Commands
    [CommandMethod("T2S")]
    static public void UpdateSpreadsheetFromTable()
      Document doc =
        Application.DocumentManager.MdiActiveDocument;
      Database db = doc.Database;
      Editor ed = doc.Editor;
      PromptEntityOptions opt =
        new PromptEntityOptions(
          "\nSelect table with spreadsheet to update: "
      opt.SetRejectMessage(
        "\nEntity is not a table."
      opt.AddAllowedClass(typeof(Table), false);
      PromptEntityResult per =
        ed.GetEntity(opt);
      if (per.Status != PromptStatus.OK)
        return;
      Transaction tr =
        db.TransactionManager.StartTransaction();
      using (tr)
        try
          DBObject obj =
            tr.GetObject(
              per.ObjectId,
              OpenMode.ForRead
          Table tb = (Table)obj;
          // It should always be a table
          // but we'll check, just in case
          if (tb != null)
            // The table must be open for write
            tb.UpgradeOpen();
            // Update the data link from the table
            tb.UpdateDataLink(
              UpdateDirection.DataToSource,
              UpdateOption.ForceFullSourceUpdate
            // And the spreadsheet from the data link
            ObjectId dlId = tb.GetDataLink(0, 0);
            DataLink dl =
              (DataLink)tr.GetObject(
                dlId,
                OpenMode.ForWrite
            dl.Update(
          tr.Commit();
          ed.WriteMessage(
            "\nUpdated the spreadsheet from the table."
        catch (Exception ex)
          ed.WriteMessage(
            "\nException: {0}",
            ex.Message
Jayhar.M.J
Please Subscribe YouTube Channel
https://www.youtube.com/channel/UCclj8v9vHQiFa8_DriuAk3w
Please Mark the Post or Posts as Solution(s) to help others find the answer quickly.
moogalm
Autodesk Support
Autodesk Support
I suggest you get comfortable with AutoCAD API programming, please go through AutoCAD Getting Started Tutorials
MyFirstAutoCADPlugin
And, self paced AutoCAD .NET Training Labs -
