How do you test commands?
stefanome
stefanome
I am working on a large addin with hundreds of commands. It is a port from an older environment that I have created over the past 25 years on another CAD.
In the old CAD I have a test suite with some tests testing simple functions and other tests that open a start drawing, run a few commands, open a second reference result drawing and compare the two drawings. The drawings are compared entity by entity, reporting any difference other than floating point errors and entities appearing in different order.
I would like to do something similar with the new AutoCAD addin, where I have a test suite with functions that open the start and reference drawings, execute a few commands and compare the result with the reference.
Is there a good or a better way to do this?
How do you test your addins?
Anton_Huizinga
I guess you mean unit testing. That is kind of a mechanism to run your code to check if every function works as expected and not has accidentally changed in the development process. You could google 'how to unit test' to find ideas how to do that.
stefanome
I do have some tests that run small functions.
Those tests work well for functions that return a value, but I also like to open a drawing, select some entities, run a command with them, and check the result against a reference result drawing. All forms used by the commands in my old addin are compatible with the test environment: a test can tell the form "you are being tested, here is the input you need to provide", so I can test commands that require user interaction with a dialog. All commands that require user input also accept something like "you are being tested, pretend the user is picking on this point".
In my old addin I have a folder full of start and result drawings and a test suite that opens each start drawing, runs one or more commands, provides input to forms, picks, selections, and compares the result with the result drawing.
Is there a similar way to test AutoCAD commands?
stefanome
I have a run configuration that has acad.exe in the "Exe path". When I run that run configuration, AutoCAD starts and loads the dll. Then I can execute any of my commands and the IDE will stop at any breakpoint. This is how anyone works on AutoCAD addins.
How do I do something similar in a test suite, but where AutoCAD is automatically executed before each test, then the test suite waits for AutoCAD to be ready, then opens a drawing, executes a command and checks the result, then, either after the successful test or the failed test or the AutoCAD crash, it starts again with another AutoCAD session and another test?
The problem is not checking the result. I can create a function that scans the result drawing and a reference drawing and compares them. The problem is how to manage the execution of AutoCAD.
If I restart AutoCAD for every single test, the test suite will take days to run.
If I start AutoCAD only once, the test suite will cover only the tests until AutoCAD crashes.
In my old environment I had each test starting its own cad session, then testing a group of commands. This would ensure a decent coverage, because even if every test crashed, the next test would start and it would run a few tests before crashing again.
norman.yuan
You can/should consider to use AutoCAD core console for the test. That is, for each method to be tested, you can start an instance of the core console (with input drawing as start argument and a script input to load the addin DLL and execute a custom command specific for the test (meaning, the the addin, you may define many CommandMethods only meant for testing).
Norman Yuan
Drive CAD With Code
stefanome
The core console would be a great help to speed up certain tasks, but I want to test commands including the selection by pick or by window.
Here is the solution I came up with. So far I have only two little tests and each test doesn't do much. But it works and it's promising. I would like any comment, "it's great", "it sucks" or "you are reinventing the wheel" are all welcome (I really hope to get the third one).
The test suite uses an iterator to go through all the subfolders of the Tests folder. Each subfolder represents a test consisting in an AutoCAD session that executes a script. So if I want to add a test, I just need to create a new subfolder, there is no need to add code to the test suite.
Here are 2 test folders, JointLines and JointLines2:
Each folder contains the following:
  • One or more start dwg file, usually one
  • One or more reference dwg files, usually many
  • The file Script.scr, containing the steps that the test must execute
  • The file TestConfiguration.json, containing some info used by the test suite. So far I have only one "KillAfterSeconds" parameter that tells the test suite to kill AutoCAD if it doesn't complete the test quickly enough
  • The file RunTest.cmd. This is not required, but it's handy to start AutoCAD with the script just like the test suite will do
  • The file Log.txt. This is deleted when the test suite starts, and it's created when the test runs
The file Script.scr opens a start drawing, executes some commands on it, then executes the "CompareWithReferenceDrawing <reference dwg path>" command, then repeats either with the same start drawing and different commands and reference drawings or with different start drawings. The "CompareWithReferenceDrawing" command compares all the entities in the current drawing (that is the result of the commands executed in the start file by the script) with the entities in the reference drawing, and appends the result of the comparison to Log.txt. The test suite looks at Log.txt to report any test failure.
The tests are executed by the following test suite:
using System.Collections;
using System.Collections.Generic;
using System.Diagnostics;
using System.IO;
using System.Text.RegularExpressions;
using System.Threading;
using NUnit.Framework;
using Newtonsoft.Json;
namespace Tests;
[TestFixture]
public class CommandsFromFoldersTests
    private const string CoreConsolePath = "C:/Program Files/Autodesk/AutoCAD 2023/accoreconsole.exe";
    private const string AutoCadPath = "C:/Program Files/Autodesk/AutoCAD 2023/acad.exe";
    private const string DirectoryWithTestsDirectories = "C:/workspace/AutoCAD/IntelliClad/Tests/Tests";
    private static IEnumerable TestCases
        get
            foreach (var directory in Directory.GetDirectories(DirectoryWithTestsDirectories))
                yield return new TestCaseData(directory);
    [Test, TestCaseSource(nameof(TestCases))]
    public void CommandFromFolderTest(string folderPath)
        var configurationFile = $"{folderPath}/TestConfiguration.json";
        var scriptFile = $"{folderPath}/Script.scr";
        var logFile = $"{folderPath}/Log.txt";
        var jsonString = File.ReadAllText(configurationFile);
        var testConfiguration = JsonConvert.DeserializeObject<Dictionary<string, object>>(jsonString);
        var killAfterSeconds = (int)(long)testConfiguration["KillAfterSeconds"];
        // delete log and done files
        if (File.Exists(logFile)) File.Delete(logFile);
        // prepare arguments for starting AutoCAD and running the script
        var startInfo = new ProcessStartInfo
            FileName = AutoCadPath,
            Arguments = $"/b \"{scriptFile}\"",
            UseShellExecute = false,
            RedirectStandardOutput = true,
            RedirectStandardError = true
        // start AutoCAD
        using (var process = new Process())
            process.StartInfo = startInfo;
            process.EnableRaisingEvents = true;
            process.Start();
            Assert.IsNotNull(process, $"Failed to start {AutoCadPath}");
            // setup a timer to kill the process after killAfterSeconds seconds
            var timer = new Timer((state) =>
                if (!process.HasExited)
                    process.Kill();
                    Assert.Fail($"AutoCAD was killed because the test was not completed within {killAfterSeconds} seconds.");
            }, null, killAfterSeconds * 1000, Timeout.Infinite);
            // wait for process to complete
            process.WaitForExit();
            timer.Dispose();
        // fail the test if the log file contains a line with "=== ERROR ==="
        // (created by CompareWithReferenceDrawing)
        Assert.IsTrue(File.Exists(logFile), "Missing log file.");
        var testResult = File.ReadAllText(logFile);
        var match = Regex.Match(testResult, @"=== ERROR ===\n(.*)", RegexOptions.Multiline);
        if (match.Success)
            Assert.Fail(match.Groups[1].Value);
Below is an example of a Script.scr file.
This script opens Start.dwg, starts the SetJointLine command, picks two points (that is selects two entities), then sets the joint size to 1. Repeats again with two different points and a different joint size. Then starts the command CompareWithReferenceDrawing which compares the current drawing (as is, after running SetJointLine twice) with the reference drawing SetJointLine2NewValues.dwg.
Then the script closes the file, reopens it, executes the same commands but with different joint sizes and compares the result with SetJointLine1New1ExistingValue.dwg.
Then the script closes AutoCAD.
;test SetJointLine with two new joint size values
Open
"C:/workspace/AutoCAD/IntelliClad/Tests/Tests/JointLines/Start.dwg"
Zoom
E
SetJointLine
244,-110
244,-85
1
SetJointLine
244,-60
244,-40
2
"C:/workspace/AutoCAD/IntelliClad/Tests/Tests/JointLines/SetJointLine2NewValues.dwg"
Close
Y
;test SetJointLine with one new and one existing joint size values
Open
Zoom
E
SetJointLine
244,-110
244,-85
0.375
SetJointLine
244,-60
244,-40
0
"C:/workspace/AutoCAD/IntelliClad/Tests/Tests/JointLines/SetJointLine1New1ExistingValue.dwg"
Quit
Y
The last two pieces of the puzzle are the commands CompareWithReferenceDrawing and SelectEntityByDrawingNameAndHandle. I have two implementations that are good enough for a proof of concept (i tested the test suite and I get success or failure as expected), but nothing that I can show yet.
CompareWithReferenceDrawing creates a list of entities from each of the drawings and compares them. The comparison considers points identical when they are almost identical, considers some entity properties like color or layer and ignores others. The entity lists from the two drawings are sorted so that two drawings that "look" the same are considered the same, even if their entities appear in different order. A change in an algorithm could cause the order entities are generated to change, which shouldn't cause the test to fail.
When two entities are different, one line containing "=== ERROR ===", one line with the description of the difference, something like "Line has wrong layer" and one line containing "SelectEntityByDrawingNameAndHandle <dwg name> <entity handle>" are added to the log file.
SelectEntityByDrawingNameAndHandle opens a file and zooms to the specified entity. I can select a line from the log file, paste it in AutoCAD command line and the drawing will open and the entity will be selected and zoomed to.
Here is an example of the log file with two failures (the test suite will only report the first one):
=== ERROR ===
Line with different start point: (315.xxx-xxxxxxxx,-99.722123995678,0) - (223.833839706771,-27.722123995678,0)
SelectEntityByDrawingNameAndHandle C:\workspace\AutoCAD\IntelliClad\Tests\Tests\JointLines\Start.dwg: 2928
SelectEntityByDrawingNameAndHandle C:\workspace\AutoCAD\IntelliClad\Tests\Tests\JointLines\SetJointLine2NewValues.dwg: 2954
=== ERROR ===
Different color: 255,0,0 - BYLAYER
SelectEntityByDrawingNameAndHandle C:\workspace\AutoCAD\IntelliClad\Tests\Tests\JointLines\Start.dwg: 2908
SelectEntityByDrawingNameAndHandle C:\workspace\AutoCAD\IntelliClad\Tests\Tests\JointLines\SetJointLine1New1ExistingValue.dwg: 2908
Here is the test result of the test suite with two folders:
