How do I copy a layer with C#?
sonny3g
sonny3g
I need to "clone" or copy a layer in a drawing and then rename it use C#.  What I am starting with is the layer name of a MLeader object that I need to create a new MLeader object on a different layer with the same properties as the layer the original MLeader object is located on.
Right now, I have the layer name of the existing MLeader and have created the new layer name.  I am able to change to the new layer if it exists, but if it does not, I have to create the new layer and then change to it before creating the new MLeader object.
I am struggling with retrieving the layer color from the original MLeader object layer.  The MLeader color is by layer, so I have to get the color from the layer itself.
Code so far:
[CommandMethod("SetUnitLayerSibling")]
private static void SetUnitLayerSibling(Database acCurDb, Document acDoc, string ulLayNam)
using (Transaction lTrans = acCurDb.TransactionManager.StartTransaction())
// Getting and setting MLeader layer information
String MtrLayName;
String tag;
MtrLayName = ulLayNam.Replace("_UNIT", "_MTR");
LayerTable lTbl;
lTbl = lTrans.GetObject(acCurDb.LayerTableId, OpenMode.ForRead) as LayerTable;
if (lTbl.Has(MtrLayName) == true)
// Set the layer
acCurDb.Clayer = lTbl[MtrLayName];
else
// Get unit layer parameters
LayerTableRecord ulRec;
// Clone unit layer and re-name
LayerTableRecord lTblRec = new LayerTableRecord();
lTblRec.Color =
lTrans.Commit();
Thanks in advance!
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
Juergen_Becker
give this a try.
The LayerTableRecord has a Clone Methode which you can use.
LayerTableRecord m_LayerTableRecord = new LayerTableRecord();
LayerTableRecord m_LayerTableRecordCloned = null;
m_LayerTableRecordCloned = (LayerTableRecord)m_LayerTableRecord.Clone();
Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
_Tharwat
Manual method here. Smiley Happy
        public static void CloneLayerName ()
            Document doc = App.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor ed = doc.Editor;
            String Old = "OldLayer";
            String New = "NewLayer";
            using (Transaction lTrans = db.TransactionManager.StartTransaction())
                LayerTable lTbl = (LayerTable)lTrans.GetObject(db.LayerTableId, OpenMode.ForWrite);
                if (lTbl.Has(Old) && !lTbl.Has(New))
                    using (LayerTableRecord lay = new LayerTableRecord())
                        LayerTableRecord Oldlayer = (LayerTableRecord)lTbl[Old].GetObject(OpenMode.ForRead);
                        lay.Name = New;
                        lay.Color = Oldlayer.Color;
                        lay.LineWeight = Oldlayer.LineWeight;
                        lay.LinetypeObjectId = Oldlayer.LinetypeObjectId;
                        lay.Description = Oldlayer.Description;
                        lTbl.Add(lay);
                lTrans.Commit();
sonny3g
Thanks.  These posts got me to where I needed to go.  Here is my code snippet that is doing exactly what I needed done.
string MtrLayNam = ulLayNam.Replace("_UNIT", "_MTR");
LayerTable lTbl;
//SetUnitLayerSibling(acCurDb, acDoc, ulLayNam);
if (lTbl.Has(MtrLayNam) == false)
LayerTableRecord lRec;
lTbl.UpgradeOpen();
lRec = lTrans.GetObject(lTbl[ulLayNam], OpenMode.ForRead).Clone() as LayerTableRecord;
lRec.Name = MtrLayNam;
lTbl.Add(lRec);
lTrans.AddNewlyCreatedDBObject(lRec, true);
lTrans.Commit();
acCurDb.Clayer = lTbl[MtrLayNam];
//lTrans.Commit();
Thanks again!!
Scott G. Sawdy
