Help with AuditInfo constructor
Paulio
Paulio
Can anyone help me with the constructor for the AuditInfo please?
I think I need to use AuditInfo.Create(type as system.type,unamanagedPointer as System.IntPtr, autoDelete as boolean) but I don't know what I should pass to it.
Can't do:
Dim ai As New AuditInfo()
 as "Sub New is not accessible in this context because it is 'Friend'"
I've had a look around but can't find a sample anywhere.
TIA
Paulio
OK. Got a bit further.
After a bit of (un)educated guessing I came up with this:
            Dim ai As AuditInfo = AuditInfo.Create(GetType(AuditInfo), db.UnmanagedObject, True)
            db.Audit(ai)
 but now I'm getting an 'eNotImplementedYet' error.
I finally figure out the constructor and then find out I can't use it yet! (unless I still haven't got the constructor right)
Is there no way to programmatically audit a database? I would use Tony T's commandline but can't becuse I'm looping through drawings in a folder which requires my commandmethod to have the sessionflags.
See the native ObjectARX docs for AcDbDatabase::audit
It's not implemented.
You can still use CommandLine to run AUDIT, but isn't that command
indeterminate (e.g., you can't anticipate what prompts it will issue) ?
For batch processing, you can use the classes in this sample,
which also solves the syncronous command problem:
  http://www.caddzone.com/AcBatchProcessSample.zip
Paulio
Awesome! Thanks Tony.
I'd love to know how it works though!
wesbird
Hi Tony:
  I tried your code, I found there are 2 files missing: Application.cs and ExtensionApplicaitonInfo.cs so I cannot compile it. Would you kindly provide a update version. I learn a lot from your code. I will keep doing so. Thank you so much.
Wes
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
