Having problems just getting setup with Visual Studio 2022
Julio_Soto
Advisor Advisor
Julio_Soto
I'm trying to start learning how to write plugins for AutoCAD 2025. I've been writing LISPS for several years now. However, I'm having a problem just getting visual studio setup.
I have VS2022 17.13.2 up and running. I start a new project using Class Library (.Net Framework) for C#.  But right off the bat I have an issue, there is no NET 8 option.
I know I have Net 8 installed
I've tried various "fixes" like enabling net previews, I tried tweaking the json files with net 8. nothing works.
I tried using 4.8 and ran into compatibility issues. What am I missing here?
essam-salah
hi
.Net Framework 4.7.2 the way to go to make a plugin works for C3D 2020 to 2025
Jeff_M
@Julio_Soto  Select the Class Library type for 2025+. The .NET Framework type is for 2024 and lower.
Julio_Soto
@Jeff_M
When creating a new project I filter for "Class Library" I don't see anything referring to 2025.
Julio_Soto
@essam-salah
Since 2025 is transitioning to Net 8 and I'm just starting, I might as well go with the latest.
Jeff_M
@Julio_Soto no, I meant you must use the Class Library option for AutoCAD 2025 and above...the first one in the list in your image.
kerry_w_brown
@Julio_Soto
The AutoCAD 2025 docs are a help this year
https://help.autodesk.com/view/OARX/2025/ENU/?guid=GUID-23E33075-3C36-48CA-B937-B85606B77F71
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
