Hi all,
When I try to insert a block with attributes in a side loaded dwg with the following code I get the error wrong database at the line brBlock.AttributeCollection.AppendAttribute(ar); . Can someone point me in the right direction of what I'm doing wrong?
Thanks in advance.
using (Database targetDb = new Database(false, true))
using (Transaction tr = targetDb.TransactionManager.StartTransaction())
targetDb.ReadDwgFile(file, FileOpenMode.OpenForReadAndAllShare, true, "");
targetDb.CloseInput(true);
bool bFixErrors = true;
bool becho = true;
ImportAlstomFiles.TransformDwg.InsertTbmBlock(targetDb);
targetDb.Audit(bFixErrors, becho);
targetDb.SaveAs(file, DwgVersion.Current);
tr.Commit();
public class TransformDwg
public static void InsertTbm(Database db)
string[] files = Directory.GetFiles(@"C:\ProgramData\Autodesk\ApplicationPlugins\SpNwDo.bundle\Contents\Block\Alstom\", "*.dwg");
foreach (string file in files)
string blockname = Path.GetFileNameWithoutExtension(file);
using (Transaction tr = db.TransactionManager.StartTransaction())
Database tmpDb = new Database(false, true);
tmpDb.ReadDwgFile(file, FileShare.Read, true, "");
db.Insert(blockname, tmpDb, true);
tr.Commit();
// Variables to hold attribute values
string blocknum = string.Empty;
string station = string.Empty;
string zone = string.Empty;
string lijn1 = string.Empty;
string lijn2 = string.Empty;
string lijn3 = string.Empty;
Point3d insPoint = new Point3d();
// Open BlockTable and BlockTableRecord
BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
// Retrieve the inserted block definition
BlockTableRecord btrBlock = tr.GetObject(bt["Alstom_TBM_DATA01_S_N"], OpenMode.ForRead) as BlockTableRecord;
// Loop through the inserted block references and retrieve attribute values
foreach (ObjectId btrId in btr)
if (btrId.ObjectClass.DxfName == "INSERT")
BlockReference br = tr.GetObject(btrId, OpenMode.ForWrite) as BlockReference;
SymbolTableRecord str = tr.GetObject(br.DynamicBlockTableRecord, OpenMode.ForRead) as SymbolTableRecord;
if (str.Name.StartsWith("*U"))
foreach (ObjectId brId in br.AttributeCollection)
AttributeReference ar = tr.GetObject(brId, OpenMode.ForRead) as AttributeReference;
if (ar.Tag == "AT_DATA_ZONE_N") zone = ar.TextString;
if (ar.Tag == "AT_DATA_STATION_N") station = ar.TextString;
if (ar.Tag == "AT_DATA_BLOCKNUM_N") blocknum = ar.TextString;
if (ar.Tag == "AT_DATA_DESC1_S_N" && lijn1 == string.Empty)
if (ar.TextString.Contains("XXX"))
else
lijn1 = ar.TextString;
if (ar.Tag == "AT_DATA_DESC2_S_N" && lijn2 == string.Empty)
else
lijn2 = ar.TextString;
if (ar.Tag == "AT_DATA_DESC3_S_N" && lijn1 == string.Empty)
else
if (ar.Tag == "AT_DATA_DESC4_S_N" && lijn2 == string.Empty)
else
if (ar.Tag == "AT_DATA_DESC5_S_N" && lijn3 == string.Empty)
else
lijn3 = ar.TextString;
insPoint = br.Position;
using (BlockReference brBlock = new BlockReference(insPoint, btrBlock.ObjectId))
btr.UpgradeOpen();
// Append the new BlockReference to PaperSpace
btr.AppendEntity(brBlock);
tr.AddNewlyCreatedDBObject(brBlock, true);
// Loop through BlockTableRecord to create AttributeReferences
foreach (ObjectId btrBlockId in btrBlock)
AttributeDefinition ad = tr.GetObject(btrBlockId, OpenMode.ForWrite) as AttributeDefinition;
if (ad != null)
// Create a new AttributeReference in the correct database (db)
using (AttributeReference ar = new AttributeReference())
// Set the attribute values and transformation
ar.SetAttributeFromBlock(ad, brBlock.BlockTransform);
// Update the text for each attribute based on collected values
ar.TextString = zone;
ar.TextString = station;
ar.TextString = blocknum;
if (ar.Tag == "AT_DATA_DESC3_S_N")
ar.TextString = lijn1;
if (ar.Tag == "AT_DATA_DESC4_S_N")
ar.TextString = lijn2;
if (ar.Tag == "AT_DATA_DESC5_S_N")
ar.TextString = lijn3;
// Add the AttributeReference to the BlockReference's AttributeCollection
// Ensure the attribute is added to the transaction
tr.AddNewlyCreatedDBObject(ar, true);
