Getting Geometry and Texturing data from entities (through WorldDraw?)
akolymparis
akolymparis
Greetings all.
While trying to find ways to optimize some old code I had made for gathering such information as geometry (vertices/faces/normals) and material properties from entities, I stumbled upon this [very interesting post].
After I tried out some stuff I managed to retrieve some data for most kinds of 3D entities but here's the problem:
My understanding was that worldDraw is the same method everyentity calls to draw itself in the editor and thus I was expecting/hoping to have access to information like texture UV coordinates and on the way autocad draws lines with dashed linetypes etc. But I found that was not the case.
I have overriden WorldGeometry, WorldDraw and SubEntityTraits as per the example and I jave implemented some code in the calls that actually give me geometric information back. For example, through Shell() I have retrieved geometry for all solids, meshes and surfaces I've tried, but no matter how i've set their materials and material mapping, the faceData do not contain a material mapper and vertex data do not contain any texture coordinates, they are simply null.
Is there a way to access that information besides calculating UVs for every entity (my previous code did that, but I would rather use something native)?
Thank you in advance for any answers!
akolymparis
Bumping.
Still looking for answers 😃
johnteng00
I want the same info, looks like with ObjectARX, we may not be able to get it. Have you tried to post the question to the development net work?
akolymparis
Hey there.
No actually I haven't tried that. Embarrassingly enough.
Will do though.
