Problem Installing and running C-Sharp with Visual Studio Express on my computer
ganderson
Message 1 of 8
ganderson
I have installed Visual Studio Express and the ARX Wizard on my lap top with the hope of running the programs that I developed on my desktop away from the office. The installation seemed to be fine (I see the AutoCad C# plug in) and can compile my code, but when I do a NETLOAD in AutoCad, nothing happens. I noticed that when I start a project, I don't get a .csproj file, only a .csproj.user file. Can someone help me get this going?
                  ~Vonnie
Replies (7)
Message 2 of 8
CADbloke
Use the https://www.visualstudio.com/en-us/products/visual-studio-community-vs.aspx instead, it is basically the Pro version for free.
working on all sorts of things including www.tvCAD.tv & www.CADreplace.com
Message 3 of 8
ganderson
This download is for Visual Studio, I thought we were supposed to run Visual Studio Express. Will this work with the AutoDesk Wizard?
             Thanks for your help.
                              ~Vonnie
Message 4 of 8
CADbloke
Yes, it will work much better with Wizards etc than the Express versions. There is really no good reason to use Express any more when the Community version is so much better - and free (unless you area big business),
You don't really need the wizards - they just add a few references and set copylocal to false and add a class or 2.
Message 5 of 8
ganderson
I've installed Visual Studio 2015 but don't see the Autodesk template or the C# plug in. Do I need to reinstall the ObjectARX stuff again?
                    ~Vonnie
Message 6 of 8
CADbloke
Yes but the wizards they've posted on Github are quite out of date - https://github.com/ADN-DevTech/AutoCAD-Net-Wizards and also, they tend to be slow in supporting the newest versions of Visual Studio.
The wizards at http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112 only support up to Visual Studio 2013.
That's how they do things in this space ... s l o w l y.
Message 7 of 8
Hey It seems like you have some knowledge on this,
I am fairly new to this. I have just downloaded the Microsoft Visual studio Community 2015, and then followed by downloading a direct link to the ObjectARX 2017 SDK. After that I proceeded to downloading and running the posted AutoCAD_2017_dotnet_wizard.zip file. I went through and downloaded everything. But when I go to Microsoft Visual Studio and go to the autodesk folder/tab it is empty. Is there any advice here?
Message 8 of 8
ganderson
Did you check to see if you have your zip file in the templates folder? By default, custom templates are located in: \My Documents\Visual Studio <Version>\Templates\ProjectTemplates\<Language>\, so you should see the .zip file there. If it isn't, you could try putting it there and see if it fixes your problem.
              ~G.
