GetKeywords and '-' in the keyword
antti.kujala
Message 1 of 11
antti.kujala
I am using GetKeyWords() like this:
Snippet
var pko = new PromptKeywordOptions("Define projection:") {
                    AllowArbitraryInput = true
                foreach (var k in new[] { "X""Y""Z""-X""-Y""-Z" })
                    pko.Keywords.Add(k);
                var projection = Utils.Editor.GetKeywords(pko);
When I select any of key words starting with '-' the prompt result status is PromptStatus.OK, but the result itself is an empty string. So what is going on? I have understood that there is some special handling for certain characters, but is the '-' one of the special characters.
How I use GetKeyWords() with strings starting with '-' and where to get the documentation explaining how the get keywords really works ?
br,
Antti
Replies (10)
Message 2 of 11
SENL1362
What AutoCAD version.
This is the result for AutoCAD 2016:
       [CommandMethod("GetKW")]
        public static void GetKeyword()
            Document doc = null;
            Database db = null;
            Editor ed = null;
            try
                doc = AcadApp.DocumentManager.MdiActiveDocument;
                if (doc == null)
                    throw new System.Exception("No MdiActiveDocument");
                db = doc.Database;
                ed = doc.Editor;
                var pko = new PromptKeywordOptions("Define projection:");
                pko.AllowArbitraryInput = true;
                foreach (var k in new[] { "X", "Y", "Z", "-X", "-Y", "-Z" })
                var pr = ed.GetKeywords(pko);
                if (pr.Status != PromptStatus.OK)
                    return;
                ed.WriteMessage("\n Keyword=" + pr.StringResult);
            catch (System.Exception ex)
                if (ed != null)
                    ed.WriteMessage("\n Error in GetKeyword: {0}", ex.Message);
Message 3 of 11
antti.kujala
Autocad version is 2016. I double checked the prompt result and still the result is the same, I get empty string for all keywords starting with '-'.
If I change keywords for example:
new[] { "X", "Y", "Z", "MINUSX", "MINUSY", "MINUSZ" }
then I get the correct values from the promp result.
Message 4 of 11
SENL1362
also when you use:
instead of
Message 5 of 11
oneMSN
Did you ever find a resolution to this issue, I have a similar issue in that the stringResult is truncated after the '-'?
Message 6 of 11
oneMSN
Sadly no,  I can't remember why I was doing this and I have searched my repos for the code and cant find it.  Either I did something else to work round it or abandoned what I was doing.
Message 7 of 11
Ed__Jobe
Have you tried preceding the dash with the escape char "\"?
foreach (var k in new[] { "X", "Y", "Z", "\-X", "\-Y", "\-Z" })
Ed
How to post your code.
Message 8 of 11
kerry_w_brown
For reference:
in ac2025
using an escape char "\"  generates a compiler error :: Error CS1009 Unrecognized escape sequence
Using the code as posted by @SENL1362 in post 2  works as expected.
        return;
    ed.WriteMessage("\n Keyword= " + pr.StringResult);
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 9 of 11
Ed__Jobe
@kerry_w_brown wrote:
For reference:
in ac2025
Thanks for testing Kerry. I didn't have time. Is the backslash being replaced then?
Ed
Message 10 of 11
Ed__Jobe
Since @kerry_w_brown  tested @SENL1362 code and it worked, you should show your code that is giving you a problem. What version of acad? VS?
Ed
Message 11 of 11
kerry_w_brown
For reference:
in ac2025
using a backslash  "\-X" won't compile
using a doublebackslash  "\\-X" displays '\-X' and returns '-X'
I have no inkling about the inner workings of the Editor.GetKeywords()  method
