ExplodeToOwnerSpace problem
Hello. I have a block with some lines and Dimension. When I using explodetoownerspace() , a  Dimension seems wrong.
This problem also appear in Autocad Command In-Place Block Editing. How can I solve it? Thanks.
_gile
Try to redefine your block:
  • open the block in the block editor,
  • erase the wrong dimension
  • recreate it properly using osnaps
  • save the changes
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Thanks for you reply.
but What do you mean by "recreate it properly using osnaps"
Can I do It by .net code?
_gile
Recreate the dimension by code may be not so trivial.
But was this block created by .NET code?
If not and the code just uses a predefined block, why can't you simply "manually" redefine the block?
Gilles Chanteau
GileCAD
GitHub
I want to get these demition properties in .net code. But thanks all the same.
