Updating a Table from code does not displayed data until you double click a cell
gotMorris
Message 1 of 8
gotMorris
After my program runs the table cells appear to be empty however if I click into  cell then click out the data is there. Any help would be great.
Before clicking
After clicking
table.UpgradeOpen();
table.Cells[2, 0].TextString = autoFixture.TitleBlock.AttributeData.FirstOrDefault(d=>d.Name == "REV").Value;
table.Cells[2, 1].TextString = "FINAL- NEW DRAWING";
table.Cells[2, 2].TextString =DateTime.Now.ToShortDateString();
table.Cells[2, 3].TextString = autoFixture.TitleBlock.AttributeData.FirstOrDefault(d => d.Name == "DRAWNBY").Value;
Replies (7)
Message 2 of 8
fieldguy
are you using table.GenerateLayout() somewhere that's not shown?
Message 3 of 8
norman.yuan
You may want to try calling Editor.UpdateScreen() after the Transaction, within which the table is opened and updated, is committed.
Norman Yuan
Drive CAD With Code
Message 4 of 8
gotMorris
I haven't tried that yet. I assumed GenerateLayout was needed if I created a new Table. Is that the case?
Message 5 of 8
gotMorris
UpdateScreen didn't do the trick. I did notice ,however, that if I resize the table the cell data is appears.
Message 6 of 8
gotMorris
I am still having trouble with this issue. I have noticed that any change in the properties of the table fixes the problem. Below I show how by changing the direction to "down" then "up" again the text is displayed. I have tried Editor.UpdateScreen() and table.GenerateLayout(). Is there a way in code to refresh the table @_gile?
Message 7 of 8
_gile
I cannot reproduce what you describe.
It's quite difficult to help you seein so few code, anyway, did you try to call.table.DowngradeOpen() after editing the table?
Gilles Chanteau
GileCAD
GitHub
Message 8 of 8
gotMorris
Thanks @_gile calling DowngradeOpen() fixed my problem. I don't recall needing to use that method after calling UpgradeOpen() on other objects before.
Thanks for your help.
