Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
eTransmit does not bind xRefs
阿黄狗
Message 1 of 10
阿黄狗
With the following code, can not bind xrefs,I don't know why?
[CommandMethod("TESTETRANSMIT2022")]
public static void ETransmitDwg2022()
    TransmittalOperation tro = new TransmittalOperation();
    TransmittalInfo ti = tro.getTransmittalInfoInterface();
    ti.BindType = BindType.eBind;
    ti.depathXrefs = 1;
    ti.destinationRoot = "D:\\TransmittalSet\\";
    ti.saveVersion = SaveDwgFormat.eNoConversion;
    ti.visualFidelity = 1;
    ti.purgeDatabase = 1;
    ti.resetPlotter = 1;
    ti.includeDataLinkFile = 0;
    ti.includeDGNUnderlay = 0;
    ti.includeDWFUnderlay = 0;
    ti.includeFontFile = 0;
    ti.includeImageFile = 0;
    ti.includeMaterialTextureFile = 0;
    ti.includeNestedOverlayXrefDwg = 0;
    ti.includePDFUnderlay = 1;
    ti.includePhotometricWebFile = 0;
    ti.includePlotFile = 0;
    ti.includeUnloadedReferences = 0;
    ti.includeUnloadedXrefDwg = 0;
    ti.includeXrefDwg = 0;
    TransmittalFile tf = null;
    string dwgFile = @"D:\新建文件夹\Drawing2.dwg";
    AddFileReturnVal val = tro.addDrawingFile(dwgFile, out tf);
    tro.createTransmittalPackage();
Replies (9)
Message 2 of 10
ehsan_bahrani
hi
according to IncludeXrefDwg Property (ActiveX/ATO) Autocad Documents maybe you need to change this line:
to
    ti.includeXrefDwg = 1;
Message 3 of 10
阿黄狗
change the line " ti.includeXrefDwg = 1;"  also  didn't work ; 9C37B574-F184-4b34-A3C8-D7B78E7E9C6A.png
Message 4 of 10
ehsan_bahrani
sorry maybe i misunderstand what you want to do.
binding a xRef is complitly different from eTransmit, in other word you have to do this tasks seperately, maybe you need first bind xRef and after that try to eTransmit.
for binding you can use this documentation.
Message 5 of 10
daniel_cadext
you can use TransmittalAddFileNotificationHandler, or another Transmittal event  to preprocess  stuff.
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 6 of 10
阿黄狗
I try it like this,but also not work; the database can not change;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using AcETransmit;
using AutoCAD;
using Autodesk.AutoCAD.Runtime;
namespace ETransmitDwg2022
    internal class MyTransFileNotifier : TransmittalAddFileNotificationHandler
        public void addFileNotificationHandler(TransmittalFile pFile, TransmittalOperation pTransmit)
            if (pFile.database != null)
                AcadDatabase acDb = pFile.database;
                if (acDb != null)
                    foreach (AcadBlock block in acDb.Blocks)
                        if (block.IsXRef)
                            block.Bind(true);
        public void beginFilesGraphCreation(TransmittalOperation pTransmit) { }
        public void endFilesGraphCreation(TransmittalOperation pTransmit) { }
    internal class datahandle : TransmittalDatabaseNotificationHandler
        public int preDatabaseProcessing(object pDatabase, TransmittalFile pFile, TransmittalOperation pTransmit)
            if (pDatabase != null)
                AcadDatabase acDb = (AcadDatabase)pDatabase;
                if (acDb != null)
                        if (block.IsXRef)
                            block.Bind(true);
            return 1;
        public int postDatabaseProcessing(object pDatabase, TransmittalFile pFile, TransmittalOperation pTransmit)
                if (acDb != null)
                        if (block.IsXRef)
                            block.Bind(true);
            return 1;
        public int convertDatabase(object pDatabase, TransmittalFile pFile, TransmittalOperation pTransmit)
                if (acDb != null)
                        if (block.IsXRef)
                            block.Bind(true);
            return 1;
    public class Class1
        private static MyTransFileNotifier myTransFileNotifier = new MyTransFileNotifier();
        private static datahandle datah = new datahandle();
            tro.subscribeToAddFileNotification(myTransFileNotifier);
            tro.subscribeDatabaseNotification(datah);
            ti.depathXrefs = 1;
            string dwgFile = @"D:\00\Drawing2.dwg";
Message 7 of 10
阿黄狗
Thank you for your answer, I just want to replicate that function in the picture;I wonder how autocad is implemented , use eTransmit and Bind Dwg Files94776762-FB10-468a-B935-C5FD9D88E60A.png
Message 8 of 10
daniel_cadext
Well, that’s a bummer, wondering if you need to save the drawing so etransmit sees the changes
Message 9 of 10
阿黄狗
but the NotificationHandler can only get database, the AcadDatabase can not save, only AcadDocument can save; so use database(AcadDatabase ) can not save the drawing;1313AF37-025B-42cb-B319-D92F29278F55.pngE4BDA31B-91D3-4bb2-A2B3-5C869AD94987.png
Message 10 of 10
daniel_cadext
So, somehow you need to get the .NET version of the database, which does have a saveas method.
ARX has a global function acdbActiveDatabaseArray, I don’t know if there’s a .NET equivalent.
Or maybe there’s a way to get a .net instance of the database from COM
