erasing a selection set
a.kouchakzadeh
a.kouchakzadeh
Hello every one
and Mr. Yuan
Im completely new to .NET and I'm using C# for my coding. I got 2 questions:
1. how to erase Items in a selection set   & how to delete the selection set itself.
2. in the picture, I have created a string and named in blklayers. but because its in an If statement, the program errors in line 213 and says blklayers does not exist in the current context.
I had to change the code in line 192 and wrote if (psr.status != PromptStatus.OK) { ...}
any suggestions?
@norman.yuan
hosneyalaa
Hi
Change the number 1 by 8
_gile
The scope of 'blknames' and 'blklayers' variables is the 'Then' statement of if (psr.Status == PromptStatus.OK). In C#, the scope of a variable is limited inside the curly braces where the variable is declared.
If you want to use them outside of this scope, you have to declare them outside of theis scope (i.e. before the if statement).
Gilles Chanteau
GileCAD
GitHub
