selection set error
selection set error
a.kouchakzadeh
selection set error
a.kouchakzadeh
Im facing another problem too
line 289 shoots an error
in the exception user-Unhandled box it says this:
  Name Value Type
▶$exception{"Unable to cast object of type 'Autodesk.AutoCAD.EditorInput.SelectedObject' to type 'Autodesk.AutoCAD.DatabaseServices.Entity'."}System.InvalidCastException
whats strange is I used the same method a few lines above which is not included in the screen shot.
this is what i wrote and passed it without error:
PromptSelectionResult psr2 = ed.SelectAll();
if (psr2.Status==PromptStatus.OK)
SelectionSet selall = psr2.Value;
Edit:
I also noticed my code wont hide entities:
foreach (ObjectId obj in objallID)
Entity ent = trs.GetObject(obj, OpenMode.ForWrite) as Entity;
ent.Visible=false;
Autodesk.AutoCAD.Internal.Utils.FlushGraphics();
@Norman_Yuan
_gile
totalset is a SelectionSet.
A SelectionSet contains SelectedObject items not Entity items.
Gilles Chanteau
GileCAD
GitHub
