eNoDatabase with Inserting a block, C#
Message 1 of 11
Hi Community,
I'm developing a plugin for autocad in c# and I'm facing a problem while trying to insert some blocks in autocad. The exception thrown from autocad is:
"INTERNAL ERROR:  !dbinsert.cpp@858: eNoDatabase".
This exception occure sporadically, so I can't always reproduce it when I debug for example. Is there any way to catch/handle this exception ?
I'm catching all System.Exceptions and Autocad Runtime Exception but without success.. 😞
Thank you all in advance.
itmtha01.
Replies (10)
Message 2 of 11
Can you Show your code so that we can help you? You can also have a look in below link where you can find some code how to insert a block using C#
http://through-the-interface.typepad.com/through_the_interface/2010/01/creating-an-autocad-block-usi...
Message 3 of 11
Hi mzakiralam,
thank your for your prompt reply my code is a bit complicated. I have tried to simplify the logic as below:
        public void AddBlocksToDrawing()
            try
                Document doc = acad_App.DocumentManager.MdiActiveDocument;
                Database db = doc.Database;
                DocumentBroker broker = DocumentBroker.GetInstance();
                LinkedList<BlockReference> legendLines = broker.GetLegendLines(doc);
                using (DocumentLock docLock = doc.LockDocument())
                    using (Transaction trans = db.TransactionManager.StartTransaction())
                        BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
                        BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
                        ExplodeNestedBlocks(db, trans);
                        ClearOldBlocks(trans, btr);
                        try
                            UpdateSymbolIndex(updateSymbols, btr, trans);
                            Point3d pos = new Point3d(0.0, 0.0, 0.0);
                            foreach (string category in this.categories)
                                List<string> subCategories = new List<string>();
                                subCategories = GetSubCategories(category, btr, trans);
                                foreach (string subCategory in subCategories)
                                    if (doc == null || db == null)
                                        MessageDialog.Show("Error", "Fehler", MessageBoxButton.OK, MessageBoxImage.Error);
                                        return;
                                    List<BlockReference> allSymbols = GetAllSubCatSymbols(category, btr, trans);
                                    List<BlockReference> symbols = GetAllSubCatSymbols(category, btr, trans);
                                    pos = AddNewBlock(pos,"block1", trans);
                                    foreach (BlockReference symbol in this.bars)
                                        string count = CountSymbol(symbol, allSymbols);
                                        pos = AddBlockLine(symbol, pos, trans);
                                    foreach (BlockReference symbol in this.symbols)
                                        pos = AddBlockLine(symbol, pos, trans,);
                                    pos = AddNewBlock(pos, ,"block2", trans);
                                pos = AddNewBlock(pos, ,"block3", trans);
                            AddNewBlock(pos,,"block4", trans);
                            UpdateAttributes(btr, trans);
                        catch (System.Exception ex)
                            MessageDialog.Show("Error"+ ex.Message, "Fehler", MessageBoxButton.OK, MessageBoxImage.Error);
                        btr.Close();
                        bt.Close();
                        trans.Commit();
                MessageDialog.Show(ex.Message, "Fehler", MessageBoxButton.OK, MessageBoxImage.Error);
        public void ExplodeNestedBlocks(Database db, Transaction trans)
            foreach (ObjectId id in btr)
                BlockReference itemBlock = trans.GetObject(id, OpenMode.ForWrite) as BlockReference;
                if (itemBlock != null && bla..)
                    BlockTableRecord nestedBtr = itemBlock.BlockTableRecord.GetObject(OpenMode.ForRead) as BlockTableRecord;
                    foreach (ObjectId objId in nestedBtr)
                        BlockReference nestedItemBlock = trans.GetObject(objId, OpenMode.ForRead) as BlockReference;
                        if (nestedItemBlock != null)
                                try
                                    itemBlock.ExplodeToOwnerSpace();
                                    itemBlock.Erase(true);
                                    return;
        private void ClearOldBlocks(Transaction trans, BlockTableRecord btr)
               BlockReference itemBlock = trans.GetObject(id, OpenMode.ForRead) as BlockReference;
               if (itemBlock != null)
                   AttributeDefinition symbolType = AttributeUtil.GetAttributeDefinition(itemBlock, Const.TYPE);
                   if (bla..)
                       trans.GetObject(id, OpenMode.ForWrite).Erase();
        private void UpdateSymbolIndex(Dictionary<string, int> updateSymbols, BlockTableRecord btr, Transaction trans)
                    AttributeDefinition attrType = AttributeUtil.GetAttributeDefinition(itemBlock, Const.TYPE);
                    String symbolPrefix = AttributeUtil.GetConfigVar(Const.SYMBOL_PREFIX);
                    if (bla..)
                        try
                                string newIndex = "X";
                                BlockTableRecord srcBtr = trans.GetObject(itemBlock.BlockTableRecord, OpenMode.ForRead) as BlockTableRecord;
                                foreach (ObjectId sID in srcBtr)
                                    MText mtext = trans.GetObject(sID, OpenMode.ForWrite) as MText;
                                    if (mtext != null)
                                        string content = mtext.Contents;
                                        mtext.Contents = content + newIndex;
                                        mtext.Close();
                                        break;
                                srcBtr.Close();
                            MessageDialog.Show("Ein Fehler ist aufgetreten:" + Const.NEW_LINE + ex.ToString(), "Fehler", MessageBoxButton.OK, MessageBoxImage.Error);
                            return;
        private Point3d AddNewBlock(Point3d pos, String blockname, Transaction trans)
            try
                BlockReference newBlock = InsertBlockReference("Legend_"+blockname, blockname, new Point3d(0.0, 0.0, 0.0), trans);
                 try
                    double[] posData = GetProjDataPos();
                    newBlock.Position = new Point3d(posData[0], posData[1], 0.0);
                    Extents3d extents = newBlock.GeometricExtents;
                    double height = Math.Abs(extents.MaxPoint.Y - extents.MinPoint.Y);
                    pos = new Point3d(newBlock.Position.X, newBlock.Position.Y + height, 0.0);
                    MessageDialog.Show("Position konnte nicht ermittelt werden. " + ex.ToString(), "Fehler", MessageBoxButton.OK, MessageBoxImage.Error);
                    return pos;
                return pos;
            return pos;
        private BlockReference InsertBlockReference(string blockName, string templateName, Point3d position, Transaction trans)
            string inputFile = string.Empty;
            try
                inputFile = Path.Combine(Const.TEMPLATE_PATH, templateName + ".dwg");
            catch (System.Exception)
                throw new System.Exception("Der angegebene Pfad wurde nicht gefunden.");
            Document currentFileDoc = acad_App.DocumentManager.MdiActiveDocument;
            Database currentFileDB = currentFileDoc.Database;
            Database inputFileDB = new Database(false, true);
            try
                inputFileDB.ReadDwgFile(inputFile, FileOpenMode.OpenForReadAndReadShare, false, null);
                throw new System.Exception("Die Eingabedatei existiert nicht oder ist nicht verfügbar: " + inputFile);
            BlockTable bt = (BlockTable)trans.GetObject(currentFileDB.BlockTableId, OpenMode.ForRead);
            BlockTableRecord btr = (BlockTableRecord)trans.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
            ObjectId objId = currentFileDB.Insert(blockName, inputFileDB, true);
            BlockReference newBlock = new BlockReference(position, objId);
            btr.AppendEntity(newBlock);
            trans.AddNewlyCreatedDBObject(newBlock, true);
            return newBlock;
        private List<string> GetSubCategories(string category, BlockTableRecord btr, Transaction trans)
                    if (bla..)
                        try
                            Dictionary<string, string> attrValues = AttributeUtil.GetAllAttributes(itemBlock);
                            if (bla..)
                                 subCategories.Add(subCategory);
                            return null;
            return subCategories;
        private List<BlockReference> GetAllSubCatSymbols(string category, string subCatetory, BlockTableRecord btr, Transaction trans)
            List<BlockReference> symbols = new List<BlockReference>();
                        try
                            if (bla...)
                                    symbols.Add(itemBlock);
                            return null;
            return symbols;
        private void AddBlockLine(BlockReferencwe symbol, Point3d position, Transaction trans))
             BlockReference newBlock = InsertBlockReference("LegendLine", "template2",position, trans);
             CopySymbol(symbol,newBlock, trans);
        private void UpdateAttributes(BlockTableRecord btr, Transaction trans)
                    if (bla..)
                        AttributeUtil.SetAttribute(itemBlock, "ATT1", "0", trans);
                        AttributeUtil.SetAttribute(itemBlock, "ATT2", "0", trans);
                        AttributeUtil.SetAttribute(itemBlock, "ATT3", "0", trans);
                        AttributeUtil.SetAttribute(itemBlock, "ATT4", "0", trans);
         public static void SetAttribute(BlockReference block, string attrTag, string attrValue, Transaction trans)
            if (!string.IsNullOrEmpty(attrTag) && !string.IsNullOrEmpty(attrValue))
                try
                    block.UpgradeOpen();
                catch { }
                AttributeDefinition attrDe = AttributeUtil.GetAttributeDefinition(block, attrTag);
                if (attrDe != null)
                    if (!attrDe.Constant)
                        AttributeReference attrRe = AttributeUtil.GetAttribute(block, attrTag);
                        if (attrRe != null)
                            attrRe.TextString = attrValue;
                        else
                            using (attrRe = new AttributeReference())
                                attrRe.SetAttributeFromBlock(attrDe, block.BlockTransform);
                                attrRe.Visible = attrDe.Visible;
                                Point3d basePoint = attrDe.Position;
                                basePoint += block.Position.GetAsVector();
                                attrRe.Position = basePoint;
                                attrRe.Height = attrDe.Height;
                                attrRe.Rotation = attrDe.Rotation;
                                attrRe.FieldLength = attrDe.FieldLength;
                                if (attrDe.IsMTextAttributeDefinition)
                                    attrRe.IsMTextAttribute = true;
                                    attrRe.UpdateMTextAttribute();
                                else
                                block.AttributeCollection.AppendAttribute(attrRe);
                                trans.AddNewlyCreatedDBObject(attrRe, true);
        private void CopySymbol(BlockReference symbol, BlockReference dstBlock, Transaction trans)
            BlockTableRecord dstBtr = trans.GetObject(dstBlock.BlockTableRecord, OpenMode.ForWrite) as BlockTableRecord;
            BlockReference copy = (BlockReference)symbol.Clone();
            AttributeDefinition attrSymbolPos = AttributeUtil.GetAttributeDefinition(dstBlock, Const.SYMBOLPOS);
            if (attrSymbolPos == null)
                throw new System.Exception("Fehler: Symbolposition ist nicht definiert.");
            copy.Position = attrSymbolPos.Position;
            dstBtr.AppendEntity(copy);
            trans.AddNewlyCreatedDBObject(copy, true);
Thank you in advance !!!
itmtha01.
Message 4 of 11
Hi again,
after debuging I've noticed that the exception occured in the method: InsertBlockReference() while calling the Insert method below:
Can I make any check before trying to insert a template ??
Best regards.
Message 5 of 11
sorry for late reply. I have skimmed through your code. It seems like that you want to insert some block from an external drawing into current drawing. Am I correct? you have opened database without opening the drawing. then you did not extract those block from that database and you try to insert that into current database which is not found and throw an exception. If what I have understood is correct then have a close look into below links which may serve your purpose
http://adndevblog.typepad.com/autocad/2012/05/insert-block-from-a-different-dwg-using-net-.html
http://adndevblog.typepad.com/autocad/2012/09/copying-deepcloning-from-one-drawing-to-another-using-...
Or kindly explain if I thought wrong.
Message 6 of 11
Please modify the line:
 Modifiy  the above  line in your code with below modification, from false to true
  inputFileDB.ReadDwgFile(inputFile,System.IO.FileShare.ReadWrite, true, "");
Message 7 of 11
jeff
When opening an object with a transaction it will close it when Commited, Aborted or disposed(if not commited will call abort), so would remove calls to Close
You can also find your answers @ TheSwamp
Message 8 of 11
Hi mzakiralam,
thank your for your reply. you're right I'm inserting some blocks from external drawings into my current drawing. I've replaced the line:
like you said with this:
But unfortunately the exception still comes from time to time.
I will try now your proposed method WblockCloneObjects(). Can I get the cloned Object (my new Blockreference) back ? I want to set some attributes after copying it.
Best regards.
itmtha01.
Message 9 of 11
Hi Jeff,
thank you for your reply. I commit my transaction at the end of the process, so that can't be the problem.
Best regards.
Message 10 of 11
sorry that did not work for you. I think the problem is you have added that block reference and return it which is not commited yet. I am not sure, just guess, as I am not so expert. I think jeff want to indicate something like that. Can you just use a sub instead of returning the blockreference? I have done something like that and it works for me. Afterwards you can  find properties of that block easily. I have done something like below. sorry the code is in VB
<CommandMethod("IBLK")> Public Sub InsertBLockfromOutside()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim db As Database = doc.Database
        Dim ed As Editor = doc.Editor
        Dim blockname As String = "TestBLK"
        Dim drawingPath As String = "C:\Users\alamzaki\Desktop\Test_data\PG-VSON-4-1_afattintel_test.dwg"
        Dim blkPos As Point3d = New Point3d(0, 0, 0)
        Try
            Using tx As Transaction = db.TransactionManager.StartTransaction()
                Dim bt As BlockTable = tx.GetObject(db.BlockTableId, OpenMode.ForRead)
                Dim ms As BlockTableRecord = tx.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
                If Not bt.Has(blockname) Then
                    InsertBlock(blockname, drawingPath, blkPos, db, ms, tx)
                End If
                tx.Commit()
            End Using
        Catch ex As System.Exception
            MsgBox(ex.Message)
        End Try
End Sub
Public Sub InsertBlock(blkName As String, dwgPath As String, positon As Point3d, acDb As Database, btr As BlockTableRecord, trans As Transaction)
        Dim dbdwg As Database = New Database(False, True)
        dbdwg.ReadDwgFile(dwgPath, FileOpenMode.OpenForReadAndAllShare, True, "")
        Dim id As ObjectId = acDb.Insert(blkName, dbdwg, True)
        dbdwg.Dispose()
        Dim blkRef As New BlockReference(positon, id)
        btr.AppendEntity(blkRef)
        trans.AddNewlyCreatedDBObject(blkRef, True)
    End Sub
Message 11 of 11
I have also tried with function mode and it is working as well for me.
        Try
                    'InsertBlock(blockname, drawingPath, blkPos, db, ms, tx)
                    Dim br As BlockReference = InsertBlock1(blockname, drawingPath, blkPos, db, ms, tx)
                    MsgBox(br.Name)
                End If
                tx.Commit()
            End Using
            MsgBox(ex.Message)
        End Try
End Sub
Public Function InsertBlock1(blkName As String, dwgPath As String, positon As Point3d, acDb As Database, btr As BlockTableRecord, trans As Transaction) As BlockReference
        dbdwg.Dispose()
        Return blkRef
End Function
