drawing properties-> custom tab【.net programming】
Message 1 of 12
Hi, everyone
Now i am using c# for my autocad2014 development.
may I ask how can I get the data from this custom tab?
I hava try this , but not work, pls help.Smiley Frustrated
 String test = thisDrawing.SummaryInfo.Keywords;
Replies (11)
Message 2 of 12
pls help, really in urgent
Message 3 of 12
or can just provide me an interface to access this custom tab is ok, thx thx.
Message 4 of 12
I'm not a C# & NET user (yet)
but I read about a similar subject in this Forum VBA thread
maybe you can get some elements from and "translate" into C# and NET
Message 5 of 12
_Tharwat
Hi.
You can explore it yourself when you know that it is a property under Database.SummerayInfo
Good luck.
Message 6 of 12
_gile
You can use these extension methods.
using System.Collections;
using System.Collections.Generic;
namespace Autodesk.AutoCAD.DatabaseServices
    /// <summary>
    /// Provides extension methods for the Database type
    /// </summary>
    public static class DatabaseExtension
        /// <summary>
        /// Gets the drawing custom properties.
        /// </summary>
        /// <param name="db">Database instance this method applies to.</param>
        /// <returns>A strongly typed dictionary containing the entries.</returns>
        public static Dictionary<string, string> GetCustomProperties(this Database db)
            Dictionary<string, string> result = new Dictionary<string, string>();
            IDictionaryEnumerator dictEnum = db.SummaryInfo.CustomProperties;
            while (dictEnum.MoveNext())
                DictionaryEntry entry = dictEnum.Entry;
                result.Add((string)entry.Key, (string)entry.Value);
            return result;
        /// <summary>
        /// Gets a drawing custom property.
        /// </summary>
        /// <param name="key">Property key.</param>
        /// <returns>The property value or null if not found</returns>
        public static string GetCustomProperty(this Database db, string key)
            DatabaseSummaryInfoBuilder sumInfo = new DatabaseSummaryInfoBuilder(db.SummaryInfo);
            IDictionary custProps = sumInfo.CustomPropertyTable;
            return (string)custProps[key];
        /// <summary>
        /// Sets a property value
        /// </summary>
        /// <param name="value">Property value.</param>
        public static void SetCustomProperty(this Database db, string key, string value)
            DatabaseSummaryInfoBuilder infoBuilder = new DatabaseSummaryInfoBuilder(db.SummaryInfo);
            IDictionary custProps = infoBuilder.CustomPropertyTable;
            if (custProps.Contains(key))
                custProps[key] = value;
            else
                custProps.Add(key, value);
            db.SummaryInfo = infoBuilder.ToDatabaseSummaryInfo();
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 7 of 12
Thx for your answer and quick response.
here's the problem,
while I am using this class to get the drawing,
Autodesk.AutoCAD.Interop.Common;
however, your entension method is using Autodesk.AutoCAD.DatabaseServices, seems cant link together.
May I ask how can i fill in the this Database db by using  Autodesk.AutoCAD.Interop.Common??
return result;
Message 8 of 12
cant change “Autodesk.AutoCAD.Interop.Common.AcadDatabase”to “Autodesk.AutoCAD.DatabaseServices.Database”
here's the problem
Message 9 of 12
I'm answering mainly to learn myself from your feedbacks then to actually help the OP. though I hope I will, too
Should extension methods be possible with reference to COM namespaces ones, then I'd just use the proper COM class name instead of "Database".
Since in ActiveX the "SummaryInfo" object is accessed via the "SummaryInfo" property of "Database" or "Document" objects, whose class names are "AcadDatabase" and "AcadDocument",  and since the OP's using "Autodesk.AutoCAD.Interop.Common", then I would try "AcadDatabase"
On the other hand I think he could go on with the "totally COM" approach and use quite much the same code of the link in post #4
I'd highly appreciate you all to elaborate on what above
Message 10 of 12
_gile
Sorry.
As you wrote: "Now i am using c# for my autocad2014 development.", I thaught you wanted a .NET reply and didn't saw you use the COM/ActiveX API.
By my side, I try to avoid, as far as I can, tu use the COM API which is really less powerfull (should I say 'crappy' ?) compared the the .NET one.
Anyway, the SummaryInfo.Keywords property corresponds to an entry in the "Summary" tab.
If you want to access to the "Custom" tab entries, you have to use the following methods:
  • thisDrawing.SummaryInfo.AddCustomInfo()
  • thisDrawing.SummaryInfo.GetCustomByIndex()
  • thisDrawing.SummaryInfo.GetCustomByKey()
  • thisDrawing.SummaryInfo.NumCustomInfo()
  • thisDrawing.SummaryInfo.RemoveCustomByIndex()
  • thisDrawing.SummaryInfo.RemoveCustomByKey()
  • thisDrawing.SummaryInfo.SetCustomByIndex()
  • thisDrawing.SummaryInfo.SetCustomByKey()
Gilles Chanteau
GileCAD
GitHub
Message 11 of 12
_gile
You can do something like this (but, one more time, use .NET API instead of COM API as soon as it's possible)
namespace Autodesk.AutoCAD.Interop.Common
    public static class InteropExtension
        public static Dictionary<string, string> GetCustomProperties(this AcadDocument thisDrawing)
            AcadSummaryInfo info = thisDrawing.SummaryInfo;
            for (int i = 0; i < info.NumCustomInfo(); i++)
                string key, val;
                info.GetCustomByIndex(i, out key, out val);
                result.Add(key, val);
            return result;
Gilles Chanteau
GileCAD
GitHub
Message 12 of 12
thank you Gile
glad to see my guessing was nearly correct.
and I assure you: when in .NET I'll only use its API!
although, in regard to that, I read sometimes that there still lingers the need of COM ones for some specific purposes...
