eFileSharingViolation error when running in AutoCAD2016
Message 1 of 10
Why am I getting a eFileSharingViolation error when running in AutoCAD2016 and not in AutoCAD2014 version with this code?:
Public Sub DwgSaveAs()
Dim doc As Document = Application.DocumentManager.MdiActiveDocument
Dim dwg = doc.Database
dwg.SaveAs(doc.Name, DwgVersion.Current)
End Sub
I tryed also the code:
 dwg.SaveAs(doc.Name, False, DwgVersion.Current, doc.Database.SecurityParameters)
What is the different between those two version of AutoCAD?
Gerrit
Replies (9)
Message 2 of 10
SENL1362
2. 🙂
And Fibers (the way multiple documents are handled).
This error is not new and the advise is to not Save the current document that way.
https://www.theswamp.org/index.php?topic=42016.0
http://www.private.peterlink.ru/poleshchuk/cad/2009/Bug2apie.htm
Message 3 of 10
Thanks for your replay Senl 1362
I have seen these posts, but why works the code in Acad 2014 and not in Acad2016
Regards
Gerrit
Message 4 of 10
augusto.goncalves
We removed Fibers on AutoCAD 2015, which modifies some behaviours.
Augusto Goncalves
Twitter @augustomaia
Autodesk Developer Network
Message 5 of 10
Thanks for your answer Augusto.Concalves,
Is there another solution for?, or do i need to change my code?
If the answer is yes then wich code we have to use?
Regards, Gerrit
Message 6 of 10
augusto.goncalves
Please try:
DocumentExtension.GetAcadDocument(doc).Save()
Augusto Goncalves
Message 7 of 10
Thanks Augusto,
It works, but now i have another problem with this, because we need for a customer the only can use dwg's saved in a earlier version of AutoCAD (AC1800 - 2004) So how can i save Dwg's to this version?
I did that with this code, it works fine in AutoCad 2014 but AutoCAD2016 get a error with this:
AcDocument = Application.DocumentManager.MdiActiveDocument
AcDocument.Database.SaveAs(strPath "\" & strDir, intDwgVers)
intDwgVersion get a integer with the AutoCAD version through a combobox with this code:
Select Case cmbFileType.SelectedIndex
 Case 0
intDwgVers = DwgVersion.Newest
  Case 1
intDwgVers =DwgVersion.AC1800
  Case Else
  End Select
Gerrit
Message 8 of 10
augusto.goncalves
Can you re-append the error message?
Augusto Goncalves
Message 9 of 10
Hi Augusto,
This is the message what i get from AutoCAD 2016.
Gerrit
Message 10 of 10
augusto.goncalves
You probably need to pass a different file name, you cannot saveAs to the same file name already open. Try, for instance, saveAs to a different name (temp name).
Augusto Goncalves
