cumlitive TwistAngle problem
Message 1 of 13
I have some code that gets the twistangle from the currentviewport. It's a basic rectangle viewport. All 2d stuff in model space nothing fancy.
 There is a North arrow in the drawing in paper space. The code I've written checks the North arrow rotation to the viewport rotation to ensure they match.
It all works great except for when a user rotates the viewport multiple times. Then the twistangle goes out of wack. It's like it's accumulating the angles and not resetting. I have seen twistangle values past 900 degrees!
VPROTATEASSOC = 1
Any idea why this is happening?
Replies (12)
Message 2 of 13
Balaji_Ram
I have seen this behavior before and I do not think the Viewport TwistAngle requires that its angle is between 0 and 360.
It should be possible to bring it to that range if you desire.
if (vp.TwistAngle > 2 * Math.PI)
     vp.TwistAngle = Math.Atan2(Math.Sin(vp.TwistAngle), Math.Cos(vp.TwistAngle));
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Message 3 of 13
Thanks Balayi for the suggestion.
I'm still not getting the correct value returned from TwistAngle.  Here is a little more detail on what I am doing.
The goal of my routine is to verify that the North arrow in my drawing in paper space is rotated to the same angle as my viewport.
The North Arrow block points North when it has a 0 degree rotation.
If I grab both the North Arrow and my viewport and rotate them together. The first time I get perfect results,
North Block Rotation : 324.184244255124
ViewportTwist: 324.184244255124
Then I rotate agan and get the following;
North Block Rotation : 293.240839748065
ViewportTwist: 66.7591602519352
In the above example the if statement you suggest does not get initiated.
Is there something wrong with my logic that I can't use the ViewportTwist in this way? I don't understand where it is coming up with the 66.7591602519352.
any help would be greatly appreciated.
Coralie
Message 4 of 13
Balaji_Ram
Sorry, I will need a sample project and the drawing to reproduce the behavior at my end.
Please do not share any information that you consider confidential.
Balaji
Balaji
Message 5 of 13
Sorry it has taken me a long time to reply. Here is the code I'm running, and a sample drawing with the block and viewport.
' check north arrow
Dim myDWG As Document = DocumentManager.MdiActiveDocument
Dim database As Database = HostApplicationServices.WorkingDatabase
Dim ed As Editor = myDWG.Editor
Dim BlockRotAng As Double = 0.0 ' rotation angle of North Arrow Block
Dim UCSAngleDeg As Double = 0.0 ' UCS angle
Dim NORTHCALC As Double = 0.0
Dim vptwistInDegrees As Double = 0.0 ' viewport twist in degrees (WCS)
Using myTrans As Transaction = myDWG.TransactionManager.StartTransaction
Dim NORTHID As ObjectId = FindBlock("ntharrow")
Dim PRJNorth As Boolean = FindTxt("PROJECT NORTH")
If NORTHID.IsNull = False Then
If PRJNorth = False Then
Dim NorthBlkRef As BlockReference = NORTHID.GetObject(OpenMode.ForRead)
BlockRotAng = NorthBlkRef.Rotation
' converting Radian to degree
BlockRotAng = BlockRotAng * (180 / Math.PI)
Dim symTable As SymbolTable = CType(myTrans.GetObject(database.ViewportTableId, OpenMode.ForRead), SymbolTable)
Dim vpcount As Integer = 0
For Each id As ObjectId In symTable
Dim symbol As ViewportTableRecord = CType(myTrans.GetObject(id, OpenMode.ForRead), ViewportTableRecord)
Dim acadDoc As AcadDocument = Autodesk.AutoCAD.ApplicationServices.DocumentExtension.GetAcadDocument(myDWG)
acadDoc.MSpace = True
Dim CVport As Viewport = DirectCast(myTrans.GetObject(myDWG.Editor.CurrentViewportObjectId, OpenMode.ForRead), Viewport)
If (CVport.TwistAngle > 2 * Math.PI) Then
CVport.UpgradeOpen()
CVport.TwistAngle = Math.Atan2(Math.Sin(CVport.TwistAngle), Math.Cos(CVport.TwistAngle))
End If
Dim vptwistInRadians As Double = CVport.TwistAngle
vptwistInDegrees = Math.Abs((vptwistInRadians * (180 / Math.PI)))
NORTHCALC = BlockRotAng
ed.WriteMessage([String].Format(vbLf & "North Block Rotation : {0}", NORTHCALC.ToString))
ed.WriteMessage([String].Format(vbLf & "ViewportTwist: {0}", vptwistInDegrees.ToString))
myTrans.Commit()
acadDoc.MSpace = False
vpcount = vpcount + 1
Next
If NORTHCALC = 360 Then
NORTHCALC = 0
End If
If vptwistInDegrees = 360 Then
vptwistInDegrees = 0
End If
If vpcount = 1 And UCSAngleDeg > 0 Then
If (NORTHCALC - UCSAngleDeg) > 1 Or (UCSAngleDeg - NORTHCALC) > 1 Then
MsgBox("Check the angle of the North Arrow", , "NORTH ARROW ROTATION")
End If
End If
If vpcount = 1 And UCSAngleDeg = 0 Then
If (NORTHCALC - vptwistInDegrees) > 1 Or (vptwistInDegrees - NORTHCALC) > 1 Then
End If
End If
End If
End If
End Using
Message 6 of 13
Balaji_Ram
Sorry, I could not reproduce the problem.
Here is a recording of what i am trying using AutoCAD 2015.
In the recording you can also find two other methods - one to set the viewport twist and the other to print the viewport twist value
http://autode.sk/1zLGM6w
Please let me know if there is any additional step to reproduce the behavior.
Balaji
Balaji
Message 7 of 13
Thanks so much Balaji!
That was great, and definately the more "normal" way to rotate the view. My user's however, sometimes use the  basic "rotate" command from paperspace and rotate the viewport object with the North Arrow block at the same time to get the view they want. Then use the grips of the viewport to change it's shape back to a rectangle to fit the page. This option came out with 2010 if I recall, and my user's take advantage of it in some situations. That's when the code fails after a couple of rotates. Hope that makes sense. We only deal in 2D so this option works for them.
Rotate the first time say ~45 degrees, then another ~45, then another ~-30, etc. the viewtwist angle will be correct for the first couple, then goes off.
Hope you can reproduce the error that way.
thanks again for your help
cj
Message 8 of 13
Balaji_Ram
Hi CJ,
Can you please record the steps ?  I still cannot reproduce the behavior.
The only time i find a mismatch is when i skip or forget to select the North block while rotating.
Here is a recording :
http://autode.sk/1Kn82sa
Balaji
Balaji
Message 9 of 13
I tried using Screencast for the first time...pretty cool.
Here is the recording, I rotate the viewport the first time, everything ok, after the second rotation, the values are different.
http://autode.sk/1KpXYhU
Thanks so much for your continued effort!
cj
Message 10 of 13
Balaji_Ram
Thanks for recording a video.
I did reproduce the behavior at my end.
It seems the ViewTwist is including multiples of 360 when rotated in clockwise and counter clockwise directions.
Although it does not affect the actual viewport twist as any angle when rotated 360 degrees in either direction should not affect its numerical value.
But in your code it does affect as you require comparison with the block reference's rotation value.
A way to workaround it would be to handle it as in this code :
    <CommandMethod("Test1")> _
    Public Sub Test1Method()
        ' check north arrow
        Dim myDWG As Document = Application.DocumentManager.MdiActiveDocument
            Dim bt As BlockTable = CType(myTrans.GetObject(database.BlockTableId, OpenMode.ForRead), BlockTable)
            Dim btr As BlockTableRecord = CType(myTrans.GetObject(bt("ntharrow"), OpenMode.ForRead), BlockTableRecord)
            Dim objIdColl As ObjectIdCollection = btr.GetBlockReferenceIds(True, True)
            Dim NORTHID As ObjectId = objIdColl(0)
                    Dim CVport As Autodesk.AutoCAD.DatabaseServices.Viewport = DirectCast(myTrans.GetObject(myDWG.Editor.CurrentViewportObjectId, OpenMode.ForRead), Autodesk.AutoCAD.DatabaseServices.Viewport)
                    'If (CVport.TwistAngle > 2 * Math.PI) Then
                    '    CVport.UpgradeOpen()
                    '    CVport.TwistAngle = Math.Atan2(Math.Sin(CVport.TwistAngle), Math.Cos(CVport.TwistAngle))
                    'End If
                    myTrans.Commit()
                Next
                'If NORTHCALC = 360 Then
                '    NORTHCALC = 0
                'End If
                'If vptwistInDegrees = 360 Then
                '    vptwistInDegrees = 0
                'End If
                If vptwistInDegrees >= 360 Then
                    Dim fullCircles As System.Int32
                    fullCircles = CType(Math.Floor(vptwistInDegrees / 360), Integer)
                    vptwistInDegrees = vptwistInDegrees - 360 * fullCircles
                End If
                    End If
                End If
                    End If
                End If
            End If
        End Using
    End Sub
Hope this helps
Balaji
Balaji
Message 11 of 13
Thanks so much Balaji.
I quickly tried your code, but it is failing on
I gen an unhandled exception.
Will need to take some time to look into that. I'm a part time programmer and have gotten tied up with some other work. Hopefully next week I will get a chance to determine why the error.
thanks again
cj
Message 12 of 13
Balaji_Ram
Hi CJ,
Not a problem, please feel free to update when you get a chance to work on it.
The line that is giving an error is a replacement for "FindBlock" that you had in your original code.
Since during my tests north arrow was the only blockreference in the drawing, i simply got hold of it without the "FindBlock".
Please feel free to use your original code to find the NORTHID instead of that line.
i.e., Dim NORTHID As ObjectId = FindBlock("ntharrow")
Balaji
Balaji
Message 13 of 13
Got it to work! Thanks Balaji!
To cover both scenerio's if the user rotates both the viewport and the north arrow together, the code worked great, BUT if they did it the "traditional" way of rotating within the viewport, the routine did not show the correct North Arrow rotation due to the counterclockwise measurement, so I added the following if the original value of the north arrow does not match, then adjust it and try the match again.
' check for match, if not adjust North angle based on counterclockwise measurement
Dim angledif As Single = NORTHCALC - vptwistInDegrees
If angledif > 1 Then
If NORTHCALC > 180 Then
NORTHCALC = 360 - NORTHCALC
Else
NORTHCALC = NORTHCALC + 180
End If
End If
