Cannot Bind to Target Method
I'm working on being able to serialize C# objects to AutoCAD entities. I have a method that serializes them and I'm trying to call this method from the AutoCAD command line intended to deserialize them.
            [CommandMethod("OpenXRecord", CommandFlags.Modal)]
            public SerializeTest XMLOpen()
                Document doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                Editor ed = doc.Editor;
                Database db = doc.Database;
                SerializeTest retval = null;
                XmlSerializer serializer = new XmlSerializer(typeof(SerializeTest));                using (Transaction tr = db.TransactionManager.StartTransaction())                using (DocumentLock docLock = doc.LockDocument())
                    PromptSelectionResult acSSPrompt = ed.GetSelection();
                    if (acSSPrompt.Status == PromptStatus.OK)
                        ObjectId[] ids = acSSPrompt.Value.GetObjectIds();
                        Entity acadObj = tr.GetObject(ids[0], OpenMode.ForWrite) as Entity;
                        if (acadObj == null || acadObj.ExtensionDictionary == ObjectId.Null)
                        {                            tr.Abort();
                            return retval;
                        }                        using (DBDictionary dict = tr.GetObject(acadObj.ExtensionDictionary, OpenMode.ForRead, false) as DBDictionary)
                            if (dict.Contains("KW_PID"))
                            {                                using (Xrecord xrec = tr.GetObject(dict.GetAt("KW_PID"), OpenMode.ForRead) as Xrecord)
                                    if (xrec != null)
                                    {                                        using (ResultBuffer rb = xrec.Data)
                                            if (rb != null)
                                            {                                                using (MemoryStream stream = new MemoryStream())
                                                    TypedValue[] tvs = rb.AsArray();
                                                    if (tvs != null)
                                                        if (tvs[0].TypeCode == (short)DxfCode.Text)
                                                            string xmlString = "";
                                                            TextWriter writer = new StreamWriter(stream);
                                                            for (int i = 1; i < tvs.Length; i++)
        if (tvs[i].TypeCode == (short)DxfCode.Text)
        {        xmlString = (string)tvs[i].Value; writer.Write(xmlString);
                                                            }                                                            writer.Flush();                                                            stream.Position = 0;                                                            retval = serializer.Deserialize(stream) as SerializeTest;
                return retval;
However, when I call it, I'm greeted with this error and have no idea why as it gives no line numbers or useful debug information.
enter image description here
CADbloke
F5? Did you run it in the debugger? What did you get when you clicked "Details"?
working on all sorts of things including www.tvCAD.tv & www.CADreplace.com
