Create mutiple layer with c#
traiduong014969
traiduong014969
Hi all,
Recently i start to Learn C#.
I start with basic object is create "Name layer". So have some problem when i create multiple layer. It only appear a layer in layer table.In spite of i created two layer in my code.  You can see a snapshot below. Someone can help me fix this code
Thank you !!!
Ed__Jobe
Hi @traiduong014969
You only use the Add method once. You need to Add each layer. Also, when you post code, please use the </> button to paste code to a special window. Please use the box in the upper left of the window to choose C# as the language format. Do not use images. See code below.
ltb.Name = "Name1";
Layertb.Add(ltb);
trans.AddNewlyCreatedDBOjbect(ltb, true);
ltb.Name = "Name2";
Layertb.Add(ltb);
Ed
How to post your code.
traiduong014969
Thank for sussgestion, I have just test again code with your code. However, it only appear '' Layername2''  in layer box
[CommandMethod("CreateLayer")]
        public void CreateLayer()
            Editor ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
            Database db = AcAp.DocumentManager.MdiActiveDocument.Database;
            ObjectId layerId = db.LayerTableId;
            Transaction trans = db.TransactionManager.StartTransaction();
            LayerTable Layertb = trans.GetObject(layerId, OpenMode.ForWrite) as LayerTable;
            try
                string Layername1 = "Newlayer1";
                string Layername2 = "Newlayer2";
                if (IsexistingLayer(trans, Layertb, Layername1,  Layername2) == false)
                    LayerTableRecord ltb = new LayerTableRecord();
                    ltb.Name = Layername1;
                    Layertb.Add(ltb);
                    trans.AddNewlyCreatedDBObject(ltb, true);
                    ltb.Name = Layername2;
                    Layertb.Add(ltb);
                else
                    Application.ShowAlertDialog("Layer is existing");
            catch (Autodesk.AutoCAD.Runtime.Exception ex)
                //ed.WriteMessage("layer dupplicted");
            trans.Commit();
        private Boolean IsexistingLayer(Transaction trans, LayerTable ltb, string Layername1, string Layername2)
            LayerTableRecord Lr;
            foreach (ObjectId ob in ltb)
                Lr = trans.GetObject(ob, OpenMode.ForRead) as LayerTableRecord;
                if (Lr.Name == Layername1 & Lr.Name ==Layername2)
                    return true;
            return false;
Jeff_M
                    Layertb.Add(ltb);
                    ltb = new LayerTableRecord(); //Add this line
                    Layertb.Add(ltb);
Ed__Jobe
Sorry, I left out that you have to create a new LayerTableRecord for each layer. Also, you probably want to set the other properties of the layer besides just the Name, e.g. Color, Linetype, etc. After you get all the properties set, then you can Add the layer. If you are writing this code to add a bunch of layers to a dwg that doesn't match your template. A better method would be to open the template in a side database and just copy the layers to the current dwg.
Here is an example I have for importing page setups from a template using the CopyFrom method.
using (Transaction sourceTrans = sourceDb.TransactionManager.StartTransaction())
    // import template page setups
    // Importing page setups also brings in referenced views.
    DBDictionary sourceDict = sourceTrans.GetObject(sourceDb.PlotSettingsDictionaryId, OpenMode.ForRead) as DBDictionary;
    foreach (DBDictionaryEntry de in sourceDict)
        PlotSettings SourcePlotSettings = sourceTrans.GetObject((ObjectId)(de.Value), OpenMode.ForRead) as PlotSettings;
        PlotSettings tempPlotSettings = new PlotSettings(SourcePlotSettings.ModelType);
        tempPlotSettings.CopyFrom(SourcePlotSettings);
        tempPlotSettings.AddToPlotSettingsDictionary(destDb);
        destTrans.AddNewlyCreatedDBObject(tempPlotSettings, true);
    sourceTrans.Commit();
Ed
traiduong014969
I fixed my code via suggetion @Ed__Jobe and @Jeff_M. However when i try delete either layer and retye command. on the screen appeare a notity "Layer is existing". I do not want that. I only want that the screen appear notify when all layer in my code have layer table. If  I olny delete a layer of all layers ,  screen will not show notify.
please help me fix that
Jeff_M
@traiduong014969 I would do something more like this:
            using (Transaction trans = db.TransactionManager.StartTransaction())
                string[] layernames = { "Newlayer1", "Newlayer2" };
                LayerTableRecord ltb;
                foreach (string layername in layernames)
                    if (Layertb.Has(layername))
                        AcAp.ShowAlertDialog("Layer " + layername + " is existing");
                        continue;
                    ltb.Name = layername;
                    Layertb.Add(ltb);
                trans.Commit();
I believe this will perform as you described.
