combo box file name
combo box file name
k005
Advisor Advisor
combo box file name
k005
Hi all,
Filenames are available in the combo box in Form1.
How can I get these filenames into the dosya variable?
Thanks in advance for the help friend.
 [CommandMethod("IMPORTBLOCKREFS")] //dwg dosyasından blokları çeker.
        public static void ImportBlockReferences()
            Form1 frm3 = new Form1();
            string blokKlasor = @"E:\Gerekli\Bloklar\";
            string dosya = blokKlasor + frm3.cmbDwgler.SelectedItem;
            Mesaj(dosya, "");
            var db = HostApplicationServices.WorkingDatabase;
            using (var sourceDb = new Database(false, true))
                sourceDb.ReadDwgFile(dosya, FileOpenMode.OpenForReadAndAllShare, true, null);
fieldguy
show your "form1" code - how do you create the combo box?
k005
1***
if (tabControl1.SelectedTab == tabPage5)
string blokklasor = @"E:\Gerekli\Bloklar";
FileInfo[] files = new DirectoryInfo(blokklasor).GetFiles("*.dwg");
//cmbDwgler.DataSource = null;
cmbDwgler.DataSource = files;
2 *** this call
private void btnBlcGetir_Click(object sender, EventArgs e)
this.Hide();
Adoc.SendStringToExecute("IMPORTBLOCKREFS\n", false, false, false);
this.Close();
fieldguy
Make sure your form1 combo box is declared as "Public".
k005
I am sure.
fieldguy
Ok.  Maybe you need to add "ToString()" to your selected item.
Check the example at the link below.
https://learn.microsoft.com/en-us/dotnet/api/system.windows.forms.combobox?view=windowsdesktop-7.0#e...
k005
I solved it with get set. Thanks for your help my friend. @fieldguy
 Durum.dosyaAdiAl = cmbDwgler.SelectedItem.ToString();
