ReadDwgFile doc.Database.Insert:eSelfReference
wokeyiyognshenme
Message 1 of 9
wokeyiyognshenme
I have a bloks.dwg, there are many block definition in the  blocks.dwg. one of them called "ABC"
I want import "ABC" in my current dwg.
The following code doesn't work:   eSelfReference !!!why ???
            Document doc = CADAPP.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            try
                using (Database dbSource = new Database(false, true))
                    dbdbSource .ReadDwgFile(@"d:\blocks.dwg", System.IO.FileShare.Read, true, null);
                    dbdbSource .CloseInput(true);
                    using (DocumentLock docLock = doc.LockDocument())
                        using (Transaction trans = doc.TransactionManager.StartTransaction())
                            //insert it as a new block
                            ObjectId id = doc.Database.Insert("ABC", dbdbSource , false);
                            trans.Commit();
            catch (Exception eee)
                MessageBox.Show(eee.Message);
Replies (8)
Message 2 of 9
norman.yuan
@wokeyiyognshenme wrote:
... there are many block definition in the  blocks.dwg. one of them called "ABC"
 So, the DWG file you are to insert into current drawing database IS NOT A BLOCK drawing, rather, it is a drawing containing many block definitions. If you insert a drawing into the current database, the inserted drawing would becomes a BLOCK DEFINITION in the current drawing with the name supplied in the Database.Insert() method. So, you want the entire "blocks.dwg" inserted into current database as a block definition with name "ABC", but the intended block definition has already contained a block definition inside with the name "ABC", hence the error.
If you want to import a block definition from external drawing, which is not a block drawing and may contains multiple block definitions, you DO NOT INSERT the entire drawing; instead, you use WBlockCloneObjects() to bring in one or more block definitions in interest.
Norman Yuan
Drive CAD With Code
Message 3 of 9
_gile
To import a BlockTableRecord from an external Database, you should use WBlockCloneObjects.
EDIT, @norman.yuan replied faster.
        public static void ImportABC()
            var targetDb = HostApplicationServices.WorkingDatabase;
            var ids = new ObjectIdCollection();
            using (var sourceDb = new Database(false, true))
                sourceDb.ReadDwgFile(@"D:\blocks.dwg", FileOpenMode.OpenForReadAndReadShare, false, null);
                using (var tr = sourceDb.TransactionManager.StartTransaction())
                    var bt = (BlockTable)tr.GetObject(sourceDb.BlockTableId, OpenMode.ForRead);
                    if (bt.Has("ABC"))
                        ids.Add(bt["ABC"]);
                    tr.Commit();
                if (ids.Count == 1)
                    var mapping = new IdMapping();
                    targetDb.WblockCloneObjects(ids, targetDb.BlockTableId, mapping, DuplicateRecordCloning.Replace, false);
Gilles Chanteau
GileCAD
GitHub
Message 4 of 9
wokeyiyognshenme
your code doesn't work。
private void button8_Click(object sender, EventArgs e)
Editor ed = doc.Editor;
using (doc.LockDocument())
ImportABC();
 // Error: ePermanentlyErased。
Message 5 of 9
wokeyiyognshenme
how to use WBlockCloneObjects() could you please give an example
Message 6 of 9
_gile
Could you try it again, I corrected the code.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 9
wokeyiyognshenme
your code doesn't work.
I try it twice .
first time :
Unhandled Access Violation Reading 0x0170 Exception at CC3F58BFh
second time:
Unhandled Access Violation Reading 0x0128 Exception at CC3F58BFh
private void button10_Click(object sender, EventArgs e)
                ImportBlocks_gile(db, @"d:\abclqh.dwg");
        public  void ImportBlocks_gile (Database destDb, string filename)
                sourceDb.ReadDwgFile(filename, FileOpenMode.OpenForReadAndReadShare, false, null);
                    foreach (ObjectId id in bt)
                        var btr = (BlockTableRecord)tr.GetObject(id, OpenMode.ForRead);
                        if (!btr.IsAnonymous && !btr.IsLayout)
                            ids.Add(id);
                    tr.Commit();
                destDb.WblockCloneObjects(ids, destDb.BlockTableId, mapping, DuplicateRecordCloning.Replace, false);
Message 8 of 9
_gile
It seems there's some confusion between you two topics.
This one was to import a single block named "ABC".
Gilles Chanteau
GileCAD
GitHub
Message 9 of 9
wokeyiyognshenme
there are many block in the xxx.dwg
1 import all of the block
2 import only one
both are ok.
