setting Z value to 0 in all objects in a drawing
a.kouchakzadeh
a.kouchakzadeh
Hi every one, Im trying to remove the Z value of all objects within a drawing (similar to flatten).
this is my code, how ever I having a problem and two questions.
namespace Z_remove
    public class Class1
        private static HashSet<string> LockedLayers(Database db, Editor ed)
            var lockedLayer = new HashSet<string>();
            using (var tr = db.TransactionManager.StartTransaction())
                var layerTable = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
                foreach (ObjectId id in layerTable)
                    LayerTableRecord layer = tr.GetObject(id, OpenMode.ForRead) as LayerTableRecord;
                    if (layer.IsLocked)
                        tr.GetObject(id, OpenMode.ForWrite);
                        lockedLayer.Add(layer.Name);
                tr.Commit();
                return lockedLayer;
        private static void LockUnlockLayers(Database db, Editor ed, HashSet<string> lockedLayers, bool lockLayers)
                    if (lockedLayers.Contains(layer.Name))
                        layer.IsLocked = lockLayers;
                tr.Commit();
        [CommandMethod("NSVZ")]
        public void RemoveZ()
            var doc = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            var db = doc.Database;
            HashSet<string> lockedLayers = LockedLayers(db, ed);
            var lockLayers = false;
            LockUnlockLayers(db, ed, lockedLayers, lockLayers);
            var sSSet = ed.SelectAll();
                foreach(ObjectId objid in sSSet.Value.GetObjectIds())
                    var ent = (Entity)tr.GetObject(objid, OpenMode.ForWrite);
                        try
                            ed.Command("CHANGE", objid, "", "P", "E", 0, "","");
                            ed.WriteMessage("\n--------------------\n");
                        catch (System.Exception ex)
                            ed.WriteMessage("\nexception " + ex.Message);
                tr.Commit();
            lockLayers = true;
 the problem is when running the command every thing works perfectly fine, except there is one block reference which I can see its insertion point has a z=0, but the block reference still has an elevation. the name is *E42 which Is an anonymous block I guess. anonymous block are bad beasts which I cant even find them in the AutoCAD "insert" menu. how can I deal with them?
my first question is, if I have a nested block reference in the drawing, do I have to create a function and set each element's elevation to 0 by using a foreach loop and:
ed.Command("CHANGE", objid, """P""E"0"","");
my second question is: is there any better way to set all z values to 0?
thanks in advance
_gile
1. If not confidential, you should attach this block so that we can try to see what's wrong with ih.
2. Here're some extension methods to flatten the main 2d entities. Some other entities could be added if needed.
It works as the _CHANGE command with _Elevation option, i.e. entities must lie on a plane which is parallel to the WCS XY plane to be "flattened".
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using static System.Math;
namespace FlattenLibrary
    public static class FlattenExtension
        public static Point3d Flatten(this Point3d point) =>
            new Point3d(point.X, point.Y, 0.0);
        public static bool TryFlatten(this Entity entity)
            if (entity == null)
                throw new System.ArgumentNullException(nameof (entity));
            var tr = entity.Database.GetTopTransaction();
            bool condition;
            switch (entity)
                case DBPoint dbPoint:
                    dbPoint.Position = dbPoint.Position.Flatten();
                    return true;
                case Arc arc:
                    if (condition = arc.Normal.IsParallelTo(Vector3d.ZAxis))
                        arc.Center = arc.Center.Flatten();
                    break;
                case Circle circle:
                    if (condition = circle.Normal.IsParallelTo(Vector3d.ZAxis))
                        circle.Center = circle.Center.Flatten();
                    break;
                case Ellipse ellipse:
                    if (condition = ellipse.Normal.IsParallelTo(Vector3d.ZAxis))
                        ellipse.Center = ellipse.Center.Flatten();
                    break;
                case Line line:
                    if (condition = Abs(line.StartPoint.Z - line.EndPoint.Z) < 1E-12)
                        line.StartPoint = line.StartPoint.Flatten();
                        line.EndPoint = line.EndPoint.Flatten();
                    break;
                case Polyline pline:
                    if (condition = pline.Normal.IsParallelTo(Vector3d.ZAxis))
                        pline.Elevation = 0.0;
                    break;
                case BlockReference br:
                    if (condition = br.Normal.IsParallelTo(Vector3d.ZAxis))
                        br.Position = br.Position.Flatten();
                        foreach (ObjectId id in br.AttributeCollection)
                            var attRef = (AttributeReference)tr.GetObject(id, OpenMode.ForWrite);
                            attRef.TryFlatten();
                    break;
                case Hatch hatch:
                    if (condition = hatch.Normal.IsParallelTo(Vector3d.ZAxis))
                        hatch.Elevation = 0.0;
                    break;
                case DBText text:
                    if (condition = text.Normal.IsParallelTo(Vector3d.ZAxis))
                        if (text.Justify == AttachmentPoint.BaseLeft)
                            text.Position = text.Position.Flatten();
                        else
                            text.AlignmentPoint = text.AlignmentPoint.Flatten();
                    break;
                case MText mtext:
                    if (condition = mtext.Normal.IsParallelTo(Vector3d.ZAxis))
                        mtext.Location = mtext.Location.Flatten();
                    break;
                case Region region:
                    if (condition = region.Normal.IsParallelTo(Vector3d.ZAxis))
                        var extents = region.GeometricExtents;
                        double elevation = extents.MinPoint.Z;
                        if (elevation != 0.0)
                            region.TransformBy(Matrix3d.Displacement(Vector3d.ZAxis * -elevation));
                    break;
                default:
                    condition = false;
                    break;
            return condition;
        public static bool TryFlatten(this BlockTableRecord btr)
            if (btr == null)
                throw new System.ArgumentNullException(nameof(btr));
            var tr = btr.Database.GetTopTransaction();
            bool flattened = true;
            foreach (ObjectId id in btr)
                var entity = (Entity)tr.GetObject(id, OpenMode.ForWrite);
                if (!entity.TryFlatten()) flattened = false;
            return flattened;
        public static Transaction GetTopTransaction (this Database db)
            if (db == null) throw new Exception(ErrorStatus.NoDatabase);
            var tr = db.TransactionManager.TopTransaction;
            if (tr == null) throw new Exception(ErrorStatus.NoActiveTransactions);
            return tr;
Test command example:
        [CommandMethod("TEST")]
        public void Test()
            var doc = AcAp.DocumentManager.MdiActiveDocument;
                var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                foreach (ObjectId id in bt)
                    var btr = (BlockTableRecord)tr.GetObject(id, OpenMode.ForRead);
                    if (!btr.IsAProxy && !btr.IsDependent && !btr.IsFromExternalReference && !btr.IsFromOverlayReference)
                        btr.TryFlatten();
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
a.kouchakzadeh
Giles that was great. apart of the problem which was solved, your posts always contain some educational stuff. very appreciated sir.
now I have a couple of questions:
your code has two overloads for TryFlatten() right?
why dont you pass the transaction instead of getting the top transaction to TryFlatten()?
also in the test method, what happens if btr.TryFlatten() returns false? why does the TryFlatten has to return a boolean at all?
how can a progressMeter be added to a block table to let the user know the status when it takes too long. how should I define pm.setlimit?
how to add leaderlines and solid objects to the TryFlatten() method?
and finally, if entity is a nested block reference, do we need to loop through each id in it and pass that sub entity to TryFlatten?
_gile
Many questions...
Yes, one for the Entity type  and another one for the BlockTableRecord type. The second one calls the first one on all entities it contains.
Because I thaught these method should always be called within a Transaction, but you can easily change this if you need.
I thaught the caller should be notified if some entity in the BlockTableRecord could not be flattened. Same thing for the Entity.TryFlatten method, as some entites may not be flattened (i.e. if the entity type is not (yet) implemented or if the entity does not lies on a plane parallel to XY). My first thaught was to throw an exception in these cases but this  would require the caller to handle exceptions.
It's a long time I didn't use a ProgressMeter. You could count the number of BlockTableRecords in the BlockTable, pass this number to SetLimits and call  MeterProgress at each BlockTableRecord.
The principle is the same as for other entities: check if the entity lies on a plane parallel to XY and move them to Z=0. The way to do these tasks depends on the entity properties, you can certainly get inspiration from the already implemented ones.
While you call TryFlatten on every BlockTableRecord in the BlockTable, every block definition will be flattened.
Gilles Chanteau
GileCAD
GitHub
_gile
I simplify the Entity.TryFlatten method so that it would be easier to add new entity types.
I added someones: Leader, Mleader, Dimension, Solid, RasterImage, Mline, Ray and Xline.
            if (entity == null)
                throw new System.ArgumentNullException(nameof(entity));
            bool condition;
            double elevation = 0.0;
            switch (entity)
                    return true;
                case Arc arc:
                        elevation = arc.Center.Z;
                    break;
                case Circle circle:
                        elevation = circle.Center.Z;
                    break;
                        elevation = ellipse.Center.Z;
                    break;
                        elevation = pline.Elevation;
                    break;
                case Polyline2d pline2d:
                    if (condition = pline2d.Normal.IsParallelTo(Vector3d.ZAxis))
                        elevation = pline2d.Elevation;
                    break;
                case Line line:
                        elevation = line.StartPoint.Z;
                    break;
                case Mline mline:
                    if (condition = mline.Normal.IsParallelTo(Vector3d.ZAxis))
                        elevation = mline.VertexAt(0).Z;
                    break;
                case Ray ray:
                    if (condition = Abs(ray.UnitDir.Z) < 1E-12)
                        elevation = ray.BasePoint.Z;
                    break;
                case Xline line:
                    if (condition = Abs(line.UnitDir.Z) < 1E-12)
                        elevation = line.BasePoint.Z;
                    break;
                        elevation = br.Position.Z;
                    break;
                case DBText text:
                        elevation = text.Position.Z;
                    break;
                case MText mtext:
                        elevation = mtext.Location.Z;
                    break;
                case Dimension dim:
                    if (condition = dim.Normal.IsParallelTo(Vector3d.ZAxis))
                        elevation = dim.Elevation;
                    break;
                case Leader leader:
                    if (condition = leader.Normal.IsParallelTo(Vector3d.ZAxis))
                        elevation = leader.StartPoint.Z;
                    break;
                case MLeader mleader:
                    if (condition = mleader.Normal.IsParallelTo(Vector3d.ZAxis))
                        elevation = mleader.GetFirstVertex(0).Z;
                    break;
                case Region region:
                        elevation = region.GetPlane().PointOnPlane.Z;
                    break;
                case Solid solid:
                    if (condition = solid.Normal.IsParallelTo(Vector3d.ZAxis))
                        elevation = solid.GetPointAt(0).Z;
                    break;
                case Hatch hatch:
                        elevation = hatch.Elevation;
                    break;
                case RasterImage image:
                    if (condition = image.Orientation.Zaxis.IsParallelTo(Vector3d.ZAxis))
                        elevation = image.Position.Z;
                    break;
                default:
                    condition = false;
                    break;
            if (condition && elevation != 0.0)
                entity.TransformBy(Matrix3d.Displacement(Vector3d.ZAxis * -elevation));
            return condition;
            if (btr == null)
            return flattened;
        public static Transaction GetTopTransaction(this Database db)
            return tr;
Gilles Chanteau
GileCAD
GitHub
a.kouchakzadeh
Giles, you are great sir!
thank you very much.
宇宙无敌帅
the batter way to set all Entitys to Z=0 is Move all Entitys from Point3d(0,0,0) To Point3d(0,0,1e99) ,then Move Them from Point3d(0,0,0) to Point3d(0,0,-1e99) again
