- Mute
- Permalink
- Report
I'm having a problem where I've changed some text in a block attribute in a sideDb. The problem is that if the text is shorter or longer than before the text will be misaligned. The attribute is middle-center justified.
If I open the dwg in AutoCAD and just move the block or the attribute any distance, the text will realign itself to correct position.
Anybody else got any experience with this and have a suggestion how to solve the issue?
Thanks!
