Changed attribute text in sideDb does not re-align when justified middle/center
ottosson_mathias
ottosson_mathias
I'm having a problem where I've changed some text in a block attribute in a sideDb. The problem is that if the text is shorter or longer than before the text will be misaligned. The attribute is middle-center justified.
If I open the dwg in AutoCAD and just move the block or the attribute any distance, the text will realign itself to correct position.
Anybody else got any experience with this and have a suggestion how to solve the issue?
Thanks!
Virupaksha_aithal
Autodesk Support
Autodesk Support
See if making the side database as working database resolves your issue? refer blog https://adndevblog.typepad.com/autocad/2012/06/updating-text-alignment-.html
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
ottosson_mathias
Thanks! That was it.
