Change system variable wipeoutframe
williamdepadua
Message 1 of 8
williamdepadua
Hello!
I have a drawing and I'm going to copy some entities for a new drawing. That's ok. But I can't set the wipeoutframe variable.
newDb.wipeoutframe = oldDb.wipeoutframe
There is no such variable.
Replies (7)
Message 2 of 8
jabowabo
Autodesk.AutoCAD.ApplicationServices.Application.SetSystemVariable("WIPEOUTFRAME", <your value>)
Message 3 of 8
williamdepadua
I don't have a document for newdb
Dim newDb as New database(true, false)
Message 4 of 8
_gile
You can use Application.SetSystemVariable in a side database if you set the working database to this database (do not forget to reset the working database.
        static void SetWipeoutFrame(string fileName, short value)
            var db = HostApplicationServices.WorkingDatabase;
            using (var newDb = new Database(false, true))
                newDb.ReadDwgFile(fileName, FileOpenMode.OpenForReadAndAllShare, false, null);
                HostApplicationServices.WorkingDatabase = newDb;
                Autodesk.AutoCAD.ApplicationServices.Core.Application.SetSystemVariable("WIPEOUTFRAME", value);
                newDb.SaveAs(fileName, DwgVersion.Current);
                HostApplicationServices.WorkingDatabase = db;
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 5 of 8
williamdepadua
Thank you! It worked partially, I have a loop that selects entities in an open document and saves in newdb. It worked in the first loop, but in the second loop the result of the wrong selection
 Public Function ExportSelection(PathToExport As String, pt3min As Point3d, pt3max As Point3d, DimScale As Double, LtScale As Double, Version As DwgVersion) As Boolean
            Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Dim ed As Editor = doc.Editor
            Dim prRes As PromptSelectionResult = ed.SelectWindow(pt3min, pt3max)
'prRes.Status = ERROR
            If (prRes.Status <> PromptStatus.OK) Then Return False
            Dim objIds As ObjectIdCollection = New ObjectIdCollection()
            Dim objIdArray() As ObjectId = prRes.Value.GetObjectIds()
            For Each id As ObjectId In objIdArray
                objIds.Add(id)
            Next
            Using newDb As Database = New Database(True, False)
                VBCad.Application.LoadLinetype(newDb)
                db.Wblock(newDb, objIds, Point3d.Origin, DuplicateRecordCloning.Ignore)
                Using Tr As Transaction = newDb.TransactionManager.StartTransaction
                    Dim DsTbl As DimStyleTable = Tr.GetObject(newDb.DimStyleTableId, OpenMode.ForWrite)
                    Dim StyleName As String = ""
                    Using tr1 As Transaction = db.TransactionManager.StartTransaction
                        StyleName = TryCast(db.Dimstyle.GetObject(OpenMode.ForRead), DimStyleTableRecord).Name
                    End Using
                    If DsTbl.Has(StyleName) = False Then
                        If DsTbl.IsWriteEnabled = False Then DsTbl.UpgradeOpen()
                        Dim acDimStyleTblRec = New DimStyleTableRecord()
                        acDimStyleTblRec.Name = StyleName
                        DsTbl.Add(acDimStyleTblRec)
                        Tr.AddNewlyCreatedDBObject(acDimStyleTblRec, True)
                        db.WblockCloneObjects(db.GetDimRecentStyleList, newDb.DimStyleTableId, New IdMapping, DuplicateRecordCloning.Replace, False)
                    End If
                    Dim FileNameFont As String = ""
                    Using TrDb As Transaction = db.TransactionManager.StartTransaction
                        Dim TsTbl As TextStyleTable = TrDb.GetObject(db.TextStyleTableId, OpenMode.ForWrite)
                        If TsTbl.Has("Standard") = True Then
                            Dim acTextStyleTblRec As TextStyleTableRecord = TrDb.GetObject(TsTbl("Standard"), OpenMode.ForWrite)
                            FileNameFont = acTextStyleTblRec.FileName
                            Dim TextStyleCollection As New ObjectIdCollection
                            TextStyleCollection.Add(acTextStyleTblRec.ObjectId)
                            db.WblockCloneObjects(TextStyleCollection, newDb.TextStyleTableId, New IdMapping, DuplicateRecordCloning.Replace, False)
                            TrDb.Commit()
                        End If
                    End Using
                    If FileNameFont <> "" Then
                        Dim NewTsTbl As TextStyleTable = Tr.GetObject(newDb.TextStyleTableId, OpenMode.ForWrite)
                        Dim NewacTextStyleTblRec As TextStyleTableRecord = Tr.GetObject(NewTsTbl("Standard"), OpenMode.ForWrite)
                        NewacTextStyleTblRec.FileName = FileNameFont
                    End If
                    Dim obj As ObjectId = DsTbl(StyleName)
                    Dim DimTabbRecaord As DimStyleTableRecord = Tr.GetObject(obj, OpenMode.ForRead)
                    Dim CurrDb As Database = HostApplicationServices.WorkingDatabase
                    Dim Wpf As Integer = Autodesk.AutoCAD.ApplicationServices.Core.Application.GetSystemVariable("WIPEOUTFRAME")
                    Autodesk.AutoCAD.ApplicationServices.Core.Application.SetSystemVariable("WIPEOUTFRAME", Wpf)
                    HostApplicationServices.WorkingDatabase = CurrDb
                    newDb.SetDimstyleData(DimTabbRecaord)
                    newDb.Dimstyle = DimTabbRecaord.ObjectId
                    newDb.Ltscale = LtScale
                    newDb.Dimscale = DimScale
                    Dim vpt As ViewportTable = Tr.GetObject(newDb.ViewportTableId, OpenMode.ForRead)
                    Dim vptr As ViewportTableRecord = Tr.GetObject(vpt.Item("*Active"), OpenMode.ForWrite)
                    Dim pt2Max As Point2d = New Point2d(pt3max.X, pt3max.Y)
                    Dim pt2Min As Point2d = New Point2d(pt3min.X, pt3min.Y)
                    Dim scrSize As Point2d = ApplicationServices.Application.GetSystemVariable("screensize")
                    Dim ratio As Double = scrSize.X / scrSize.Y
                    Dim height As Double = pt2Max.Y - pt2Min.Y
                    Dim width As Double = pt2Max.X - pt2Min.X
                    If (width / height < ratio) Then
                        vptr.Height = height
                        vptr.Width = height * ratio
                    Else
                        vptr.Width = width
                        vptr.Height = width / ratio
                    End If
                    vptr.CenterPoint = pt2Min + (pt2Max - pt2Min) / 2.0
                    newDb.UpdateExt(True)
                    Tr.Commit()
                End Using
                Dim bmp As System.Drawing.Bitmap = ExtracThumbnail(newDb)
                newDb.ThumbnailBitmap = bmp
                Dim FileName As String = PathToExport
                newDb.SaveAs(FileName, Version)
            End Using
            Return True
        End Function
Message 6 of 8
_gile
Try removing:
and:
And put this just after the newDb.SaveAs(FileName, Version).
Gilles Chanteau
GileCAD
GitHub
Message 7 of 8
williamdepadua
I try, not work...
Message 8 of 8
williamdepadua
It seems that when changing the property "WorkingDatabase" the open document lost the focu, so the command "ed. SelectWindow(pt3min, pt3max)" returned an error. Also the CAD screen displayed the entities of the "newDb" that in reality did not have a document open for it, that is, it is occurring from display. To correctly display the document that is open I press the scroll twice. I believe that by doing so I was returning the focu to the open document.
So I thought I'd add the line of code.
Ed.Command("zoom", "e")
To simulate double-clicking on the scroll.
It stayed that way.
HostApplicationServices.WorkingDatabase = Db
Now everything worked properly.
The question remains, why is the error really happening and what is the correct solution?
Since my solution is not the most correct. Here in Brazil we call "gambiarra" is something that is not right, but it works.
