Screen update become slow when using GetSplitCurve() with DBObject.HangOverTo()
trithuongle
trithuongle
Good evening everyone. I have a question.
I have below code to split an original curve into 2 new curves then hangover 1 of them with original curve.
Point3dCollection splitPnts = new Point3dCollection();
                splitPnts.Add(trimPnt);
                using (DBObjectCollection splitCurvs = memCurv.GetSplitCurves(splitPnts))
                    //baseEd.WriteMessage($"\nSplit curves 's number : {splitCurvs.Count}");
                    //baseEd.WriteMessage($"\nSplit curves 's point : X = {splitPnts[0].X} , Y = {splitPnts[0].Y}");
                    //Find closet points  :
                    Point3d cloPnt1 = ((Curve)splitCurvs[0]).GetClosestPointTo(stdPnt, false);
                    Point3d cloPnt2 = ((Curve)splitCurvs[1]).GetClosestPointTo(stdPnt, false);
                    if (cloPnt1.DistanceTo(trimPnt) <= KRTolerance)
                        memCurv.HandOverTo(splitCurvs[1], true, true);
                    else
                        memCurv.HandOverTo(splitCurvs[0], true, true);
The problem is after the command is finish , the original curve is still the same and i have to drag my mouse about 1~2 seconds for screen update .
I tried to use Autodesk.AutoCAD.Internal.Utils.SetFocusToDwgView();
But it didn't work . Please help .
Thanks in advance !
hippe013
Is it possible to see your code in its entirety?
trithuongle
@hippe013
Hi , It is ok . I sent it as below .
Now ,  i also put my alternative way to achieve this , but actually i want to finish in the old way with screen update not become slow.
        void CmdTE_TrimCurves(Editor baseEd, Transaction baseTr,
                              Curve boCurv, Curve memCurv,
                              Point3dCollection intPnts, Point3d stdPnt)
            //Variable for trim point :
            Point3d trimPnt;
            //Upgrate member curve to 'OpenForWrite'
            memCurv.UpgradeOpen();
            trimPnt = intPnts[0];
            //Find point to trim :
            if (intPnts.Count > 1)
                for (int i = 1; i < intPnts.Count; i++)
                    if (stdPnt.DistanceTo(intPnts[i]) <
                        stdPnt.DistanceTo(trimPnt))
                        trimPnt = intPnts[i];
            #region [Trim curve]
            try
                Point3dCollection splitPnts = new Point3dCollection() { trimPnt };
                    Point3d cloPnt = ((Curve)splitCurvs[0]).GetClosestPointTo(stdPnt, false);
                    #region [codes part that seem to make process became slow]
                    ////Trim curve :
                    //if (cloPnt.DistanceTo(trimPnt) <= KRTolerance)
                    //    memCurv.HandOverTo(splitCurvs[1], true, true);
                    //else
                    //    memCurv.HandOverTo(splitCurvs[0], true, true);
                    #endregion
		    #region [My alternative solution for now]
                    Curve retCurv;
                        retCurv = (Curve)splitCurvs[1];
                    else
                        retCurv = (Curve)splitCurvs[0];
                    ObjectId retId;
                    using (Transaction tr = db().TransactionManager.StartTransaction())
                        retId = AppendEnt(tr, retCurv);
                        tr.Commit();
                    memCurv.SwapIdWith(retId, true, true);
                    memCurv.Erase();
  		    #endregion
            catch (System.Exception ex)
		ed.WriteMessage($"\nError : {ex.Message}");
                return;
            #endregion
Thanks in advance !
