Can't find intersections.
932189886
932189886
I can't get the intersections in the graph, anything else of the same type is fine.I don't know if this is a bug or if there is something wrong with my code. Please help me find out what the problem is. the code is simple :
Point3dCollection intersections = new Point3dCollection();
var plane = new Plane();
curve1.IntersectWith(curve2, Intersect.OnBothOperands,plane, intersections, IntPtr.Zero, IntPtr.Zero);
kerry_w_brown
I assume you're getting an error message ??
Where do you define the Plane parameters ??
It's better if you post a small self contained method to save your peers having to guess.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
_gile
It works for me with your drawing.
Testing command:
        [CommandMethod("INT")]
        public static void Int()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = doc.Database;
            var ed = doc.Editor;
            var peo = new PromptEntityOptions("\nSelect curve 1: ");
            peo.SetRejectMessage("\nSelected object is not a Curve.");
            peo.AddAllowedClass(typeof(Curve), false);
            var per = ed.GetEntity(peo);
            if (per.Status != PromptStatus.OK) return;
            var id1 = per.ObjectId;
            peo.Message = "\nSelect curve 2: ";
            var id2 = per.ObjectId;
            using (var tr = db.TransactionManager.StartTransaction())
                var points = new Point3dCollection();
                var curve1 = (Entity)tr.GetObject(id1, OpenMode.ForRead);
                var curve2 = (Entity)tr.GetObject(id2, OpenMode.ForRead);
                curve1.IntersectWith(curve2, Intersect.OnBothOperands, plane, points, IntPtr.Zero, IntPtr.Zero);
                if (0 < points.Count)
                    var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
                    foreach (Point3d pt in points)
                        var dbPoint = new DBPoint(pt);
                        curSpace.AppendEntity(dbPoint);
                        tr.AddNewlyCreatedDBObject(dbPoint, true);
                else
                    ed.WriteMessage("\nNone intersection.");
                tr.Commit();
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
_gile
Hi Kerry,
The default ctor: new plane() uses the default values: Point3d.Origin and Vector3d.ZAxis.
Gilles Chanteau
GileCAD
GitHub
THK U.I TEST YOUR CODE,BUT STILL NONE.I'M USING ACAD2016.
kerry_w_brown
happenstance  ?
default is :
Normal : {(0,0,1)}
PointOnPlane : Y = 0, X = 0
added: Gilles beat me 🙂
