It works for me with your drawing.
Testing command:
[CommandMethod("INT")]
public static void Int()
var doc = Application.DocumentManager.MdiActiveDocument;
var db = doc.Database;
var ed = doc.Editor;
var peo = new PromptEntityOptions("\nSelect curve 1: ");
peo.SetRejectMessage("\nSelected object is not a Curve.");
peo.AddAllowedClass(typeof(Curve), false);
var per = ed.GetEntity(peo);
if (per.Status != PromptStatus.OK) return;
var id1 = per.ObjectId;
peo.Message = "\nSelect curve 2: ";
var id2 = per.ObjectId;
using (var tr = db.TransactionManager.StartTransaction())
var points = new Point3dCollection();
var plane = new Plane();
var curve1 = (Entity)tr.GetObject(id1, OpenMode.ForRead);
var curve2 = (Entity)tr.GetObject(id2, OpenMode.ForRead);
curve1.IntersectWith(curve2, Intersect.OnBothOperands, plane, points, IntPtr.Zero, IntPtr.Zero);
if (0 < points.Count)
var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite);
foreach (Point3d pt in points)
var dbPoint = new DBPoint(pt);
curSpace.AppendEntity(dbPoint);
tr.AddNewlyCreatedDBObject(dbPoint, true);
else
ed.WriteMessage("\nNone intersection.");
tr.Commit();
