Can't debug my project with AutoCAD2011
Hi Guys,
I have added reference acdbmgd/acmgd from C:\Program Files\Autodesk\AutoCAD 2011\  with copy local =false I can see from the list the version are 18.0.0.0
But when I start debug the project I got the following error
This project used to work with AutoCAD2010, now just moved to 2011 I can't even start debuging
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.IO.FileLoadException: A procedure imported by 'acmgd, Version=18.0.0.0, Culture=neutral, PublicKeyToken=null' could not be loaded.
File name: 'acmgd, Version=18.0.0.0, Culture=neutral, PublicKeyToken=null' ---> System.Runtime.InteropServices.COMException (0x8007007F): The specified procedure could not be found. (Exception from HRESULT: 0x8007007F)
   at System.ModuleHandle.ResolveMethod(Int32 methodToken, RuntimeTypeHandle* typeInstArgs, Int32 typeInstCount, RuntimeTypeHandle* methodInstArgs, Int32 methodInstCount)
   at System.ModuleHandle.ResolveMethodHandle(Int32 methodToken, RuntimeTypeHandle[] typeInstantiationContext, RuntimeTypeHandle[] methodInstantiationContext)
   at System.Reflection.CustomAttributeData..ctor(Module scope, CustomAttributeRecord caRecord)
   at System.Reflection.CustomAttributeData.GetCustomAttributes(Module module, Int32 tkTarget)
   at System.Reflection.CustomAttributeData.GetCustomAttributes(Assembly target)
   at System.Resources.ResourceManager.GetNeutralResourcesLanguage(Assembly a, UltimateResourceFallbackLocation& fallbackLocation)
   at System.Resources.ResourceManager.InternalGetResourceSet(CultureInfo culture, Boolean createIfNotExists, Boolean tryParents)
   at System.Resources.ResourceManager.GetObject(String name, CultureInfo culture, Boolean wrapUnmanagedMemStream)
   at System.Resources.ResourceManager.GetStream(String name, CultureInfo culture)
   at MS.Internal.Resources.ResourceManagerWrapper.GetStream(String name)
   at MS.Internal.AppModel.ResourcePart.EnsureResourceLocationSet()
   at MS.Internal.AppModel.ResourcePart.GetStreamCore(FileMode mode, FileAccess access)
   at System.IO.Packaging.PackagePart.GetStream(FileMode mode, FileAccess access)
   at System.IO.Packaging.PackWebResponse.CachedResponse.GetResponseStream()
   at System.IO.Packaging.PackWebResponse.GetResponseStream()
   at System.IO.Packaging.PackWebResponse.get_ContentType()
   at MS.Internal.WpfWebRequestHelper.GetContentType(WebResponse response)
   at MS.Internal.WpfWebRequestHelper.GetResponseStream(WebRequest request, ContentType& contentType)
   at System.Windows.ResourceDictionary.set_Source(Uri value)
   at Autodesk.AutoCAD.Internal.Windows.RibbonContent.get_AppFrameResources()
   at Autodesk.AutoCAD.Internal.Windows.RibbonContent.get_NonZeroDocQAT()
   at Autodesk.AutoCAD.Internal.Windows.RibbonContent.GetNonZeroDocumentQATControl(String sId)
   at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.LoadQuickAccessToolbarContent(MenuGroupData menuGroupData, Dictionary`2 workspaces, Dictionary`2 quickAccessToolbarItems)
   at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.LoadContent()
   at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.RestoreItems()
   at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.Initialize()
   at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.LoadQuickAccessToolbar()
   at Autodesk.AutoCAD.Internal.Windows.QuickAccessToolbarService.OnApplicationIdle(Object sender, EventArgs e)
   at System.EventHandler.Invoke(Object sender, EventArgs e)
   at Autodesk.AutoCAD.ApplicationServices.Application.raise_Idle(Object value0, EventArgs value1)
   at Autodesk.AutoCAD.ApplicationServices.Application.OnIdle()
************** Loaded Assemblies **************
mscorlib
    Assembly Version: 2.0.0.0
    Win32 Version: 2.0.50727.4959 (win7RTMGDR.050727-4900)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
acdbmgd
    Assembly Version: 18.1.0.0
    Win32 Version: 18.1.49.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcdbMgd.DLL
System
    Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
msvcm90
    Assembly Version: 9.0.30729.4974
    Win32 Version: 9.00.30729.4974
    CodeBase: file:///C:/Windows/WinSxS/x86_microsoft.vc90.crt_1fc8b3b9a1e18e3b_9.0.30729.4974_none_50940634bcb759...
System.Xml
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Drawing
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
PresentationFramework
    Assembly Version: 3.0.0.0
    Win32 Version: 3.0.6920.5001 built by: Win7RTMGDR
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework/3.0.0.0__31bf3856ad364e35/PresentationFra...
WindowsBase
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/WindowsBase/3.0.0.0__31bf3856ad364e35/WindowsBase.dll
PresentationCore
    CodeBase: file:///C:/Windows/assembly/GAC_32/PresentationCore/3.0.0.0__31bf3856ad364e35/PresentationCore.dll
System.Configuration
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configura...
AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 3.0.264.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdApplicationFrame.DLL
AdWindows
    Assembly Version: 3.0.263.0
    Win32 Version: 3.0.263.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AdWindows.DLL
PresentationFramework.Aero
    Win32 Version: 3.0.6920.4902 built by: NetFXw7
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/PresentationFramework.Aero/3.0.0.0__31bf3856ad364e35/Presentati...
acmgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/acmgd.DLL
System.Core
    Assembly Version: 3.5.0.0
    Win32 Version: 3.5.30729.4926 built by: NetFXw7
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcWindows.DLL
AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/en-US/AcWindows.resources.DLL
AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202011/AcCui.DLL
AcWindows
    Assembly Version: 18.0.0.0
    Win32 Version: 18.0.55.0.0
    CodeBase: file:///C:/Program%20Files/Fifth%20Dimension/StorePlan%20HQ/AcWindows.dll
System.Windows.Forms
    CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.F...
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
    <system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
Any ideas?
Thanks very much
Well, I'm not sure what is causing your error, but you aren't supposed to reference the .dll files from your AutoCAD folder... you are supposed to reference them from the ObjectARX folder on C: drive. If you don't have that, you should install the ObjectARX SDK.
I'm not sure this has anything to do with your problem, but all the documentation I've read says that is the way to go, and it works for me.
Good luck and report back here if that helps or doesn't help. Maybe somebody else will have an idea.
Hi Steven,
Thanks for reply. i downloaded objectARX and re reference them to c:objectarx 2011\inc\
but the error is the sameSmiley Sad
BTW: i am using VB2008
The funny thing is I created a new project and it works fine, just the old one which works perfect in AutoCAD2010
chiefbraincloud
It does not matter where you reference the files from, the files that are loaded at runtime will still be the files from the AutoCAD directory.  (AutoCAD is loaded in the normal fashion prior to you netloading your project into AutoCAD, therefore the necessary files have already been loaded into memory and are used as such.)  The files from the ObjectARX folder will not get loaded on top of the others just because you reference them.
Think of an end user machine that does not have the ObjectARX files.
The reason for referencing the ObjectARX files is that certain dependancies have been removed from those files.
StephenPreston
Did you set Copy Local to False for the two AutoCAD assemblies?
Cheers,
Stephen Preston
Autodesk Developer Network
Cheers,
Stephen Preston
I assume you changed you project to start 2011 not 2010.
What other references are in your project.
I had some simillar problems but it came down references. Make sure all the that the paths are to AC2011 even if copy local is false.
Hi Guys,
I solved my problem by deleting local copy AcWindows.DLL.
I don't know why, but that solved the problem
Thanks for your help
